6.5 vs 5.5 ft box on screw
I have the 6.5 foot and my brother has the 5.5 foot bed. The only difference I saw was when loading stuff and needing the tailgate up. When we loaded some bailed straw, I was able to fit more with the 6.5 foot bed. Other than the straw, he can do anyting I can. Anything else and you either need straps or a trailer.
Another consideration is the maneuverability. I thought it was negligable until I drove our trucks back to back. His turns much easier and in a much tighter area. Not by much, but it is noticable.
Looks is purely subjective. I like the look of the 6.5 footer. YMMV
I'm with the 6.5 crowd as well...
I've had my Screw for almost 6 months now, and I've never had a problem with maneuvering it. As stated before, it IS too long for many parking spots, so you almost always are sticking out, but this has never bothered me too much.
One big reason that has not been mentioned is the ability to control a tow. The extra wheel base goes a long way to control sway in some large trailers. Also, it handles high tongue weights better because there is more leverage holding the front end down, meaning you retain more steering control while towing.
I've towed about 7,000 lbs with mine, and that was on a 500 mile trip, and it handled it like a champ.
Parking in a garage becomes more of an issue with the 6.5'.
That being said I would opt for the 6.5' bed. After owning both I found the 6.5' more functional when carrying skis and /or bikes. I could put five mtn bikes without taking off the wheels in my 01 supercab. More than two fit better with the wheels off in my 06 w/ 5.5'. As for skis I could carry 3-5 pair laying down one side of the 6.5' bed. The 5.5' requires the skis lay diagonally- which usually covers stuff- and can be an issue at the end of the day when the skis are covered with snow.
Tim
It all depends on how you'll use the bed.
Tim
Originally Posted by last5oh_302
When hauling lumber, which usually comes in 8 ft standard sized pieces, whether you have the 5.5 ft bed or 6.5 ft bed makes no difference. Either way, you're dropping the tailgate to fit them in. As for looks, some might argue the shorter bed looks sharper.
There are the wheelbase arguments regarding truck maneuverability as well.
Either way, unless you're carrying an ATV and want to be able to close the tailgate (even with a 6.5 footer, I'm not sure if you can close the tailgate), I don't see there being much, if any of a difference between the two beds.
That being said, I have the 5.5 footer, and I'd have no problems getting a 5.5 footer again, for what I use it for.
another thing to consider is that for the payload linear space you gain with the 6.5' bed, you lose rated weight capacity, ie the 5.5' bed has a higher payload rating
that being said, i probably should have bought a 6.5' so i could sleep in the back without lying diagonally! and to more readily fit a slide-in camper
...but i digress, lessons learned: from here on out for me, it's 3/4-1 ton and 8' bed! although i'm quite impressed with the rear suspension of my pickup, there are occasions when i could save time and $$ hauling stuff with a long bed 1 ton--like making 3 60-mile roundtrip runs to the landfill to dump 2.5 tons of brick...i had one load weigh in at 2400lbs, filled to the top of my bed and it handle it fantastic (didn't realize until i got to the scales how overloaded i was because the rear sagged so little)
I had a 05 screw with the 5.5 bed. I liked the way it handled and drove. I couldnt put my king quad in it but that is what I have the trailer for. I traded it in on a 04 F350 srw withthe 8' bed. Now that can be a pain to park and takes 2 acres to turn around. I love my superduty tho. It pulls my travel trailer much better than my screw did. I did like my F150 also. It was just time to upgrade to a diesel.
I think it really boils down to choosing between functionality verses looks.
Here in Oklahoma your not suppost to have anything sticking out of the back of the bed more than 4 feet. I had to ask a friend to haul some lumber for me a few days ago. He has an extended cab '06 F150 with an 8' bed on it. It sure is ugly but I didn't say anything while he was doing me a favor.
Originally Posted by FoundOnRoad
I have the Screw (07) with the 6.5 bed. Let me tell you it's a big a$$ truck. It definately fills my half of the garage. The only problem I'm having, is adjusting to parking spaces. You really have to swing wide to get into one. It usually takes me a couple of attempts to get it in straight. .
I love my long bed I have a retrax cover on it and still have plenty of room for my family of four's extra camping essentials ie: bikes, bbq, coolers etc...
