Rear Stabilizer Set Up
Old Aug 18, 2007 | 12:19 PM
1081's Avatar
1081
I have a 1999 Mountaineer AWD and will probably be putting shocks on it since it is a little over 93,000 miles. The rear end has developed a squeak that I can't really pin down. It could be the stabilizer bushing but I am not sure, I have tried spraying a little WD-40 in the joints to try to eliminate the noise but that didn't work. Has anyone dealt with this before? There are also small shock absorbers on the sway bar that I will probably replace also, what are these called so that the part store can find them? Also, are there sway bar bushing kits available that have all of the rear sway bar bushings and not just the two big ones?
Thanks,
Bryon
