The Next Generation For those ages 15-25.
whats your worst offroading damage?
  #61
Old 05-07-2008, 07:07 PM
chrono4's Avatar
chrono4
chrono4 is offline
well what can I say? It just sounded good at the time.
  #62
Old 05-07-2008, 07:34 PM
maverick1701's Avatar
maverick1701
maverick1701 is offline
Nothing too major...her down to the frame in this thick, sticky mud last weekend. The only damage I could find was the rear bumper being a little bent but that can be solved w/a tree and a chain.
We busted up my roommates bumper on his new JK but that was the only damage for the day!
We are going again this weekend after finals are through...hopefully nothing major will happen
On Edit: Some of these stories are HILARIOUS!
  #63
Old 05-08-2008, 11:22 AM
bansheeduner's Avatar
bansheeduner
bansheeduner is offline
look up sand addiction magazine it should still be on the web site believe what you want we are taking the truck up to flagstaff this weekend if we find any good jumps ill try to get a photo its just so hard to get out of that truck when you know how great the ride is
  #64
Old 05-08-2008, 04:39 PM
STGFordCrazy04's Avatar
STGFordCrazy04
STGFordCrazy04 is offline
Am I too old to play in this forum?
Most of you already know but for the newbs...
I completely ripped my D44HD to shreads (read - grenaded) within 3 seconds of being in 4wd.
Broke all 4 shafts (inners and outers) at the yokes, broke the short side shaft just past the splines, broke the passenger side locking hub in half, Shoved the outer stub into the face of the driver side hub popping the twist **** off, twisted the splines on the long side shaft and probably did damage to the detroit but I never pulled it before I sold the axle. This was all done with new spicer life series joints installed, not the crappy worn out stuff most of you are running.
for those who say pics or it didnt happen....
Ive also twisted the splines on 3 Moser 1541H alloy D60 FF shafts and have broken 4 or 5 (cant remember) stock shafts. Ripped the frame mount off for my traction bars (bolted on with 2- 1/2x1.5 grade 8 hex bolts) and lost the lid to my cooler while playing in the mud from June '07-present
  #65
Old 05-08-2008, 05:09 PM
captain p4's Avatar
captain p4
captain p4 is offline
All that happened at the same time? I never knew that. That makes it a lot cooler.
d44s suck!!@!
  #66
Old 05-08-2008, 05:13 PM
STGFordCrazy04
The D44 and one of the Moser shafts carnage happened at once.
June 29th 07 IIRC
  #67
Old 05-10-2008, 11:02 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
  #68
Old 05-11-2008, 06:37 PM
dukedrummer89's Avatar
dukedrummer89
dukedrummer89 is offline
A couple weekends ago i demolished my wheeler, broke the back window, smashed up my toolbox, broke my snorkel, smashed up both front fenders, grill, turn signals and markers, broken body mounts, popped a tire off the bead, blew a clutch line, and the motor idles at 2500 rpm now.... all in a days fun
  #69
Old 05-11-2008, 06:42 PM
STGFordCrazy04
it was probably in your best interest that it broke the snorkle. take that crapola off.
where are the 39.5 swampers you list in your sig? Even though the 44 wouldve probably let go eventually the tires would have cleaned and you probably wouldnt be stuck.
  #70
Old 05-11-2008, 06:57 PM
dukedrummer89
No way will i ever give up my snorkle, best mod yet, nothing like have a good supply of fresh clean air
I wasnt stuck, just a good photo, a couple weeks after that day i got my swampers, the 300 dosent have the power/rpm to clean the tires, but ive got plans for it
  #71
Old 05-11-2008, 07:04 PM
STGFordCrazy04
gears my good man. the 300 will need 4.88-5.13s to keep good 39s spinning.
what did that d44 come out of? is that a closed knuckle low pinion? I noticed how the hubs bolt on from the outside with hex bolts rather than the later style hex screws.
Do what you want with the snorkle. If youre that worried about it route it in the cab. I wouldnt do it your way because Id break the mother off every time I went out. PVC pipe belongs under houses not on mud trucks.
  #72
Old 05-11-2008, 07:13 PM
dukedrummer89
Ill get a d60 before i regear, the 44 is a high pinion, and isnt closed knuckle, i did some tradin for it, im not sure what year its out of, every part of my snorkle was free, so im not going to change it, it works fine
  #73
Old 05-11-2008, 07:16 PM
STGFordCrazy04
unsubscribed....
  #74
Old 05-11-2008, 10:43 PM
Truckin4life's Avatar
Truckin4life
Truckin4life is offline
Street Queen to the extr3m3
Originally Posted by chrono4
well first off "duner", it wasn't a personal attack on you, but it is now. I wasn't saying you actually hadn't done it, but rather that I wanted to see some pics of this INSANE stunt, because when most people do things like that, people have it on camera. Now I can believe that you haven't done it, just because you got so defensive.
Bite Me.
i concur....
Noticed there still aint any pics...
as for the snorkel...
to each his own.
Me personally i would go in the cab... But thats just me.
  #75
Old 05-26-2008, 02:49 PM
EricW.'s Avatar
EricW.
EricW. is offline
Blew the clutch out that was less than 5000mi old and ripped the grill, bumper and headlights off my '93 F-150...
Quick Reply: whats your worst offroading damage?
