75W140 or 75W90
Old 08-15-2007, 02:27 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
of FTE, RHN, and BEER!
ztodd377 is gaining momentum as a positive member of FTE.ztodd377 is gaining momentum as a positive member of FTE.
Question 75W140 or 75W90
I'm wanting the change my rear diff fluid and the owners manual calls for 75W140. I talked to a guy that owns a diesel shop up here (in Alaska) and he said I only needed 75W90, same as the front diff. Would I get better mileage? Would this cause premature wear? Can anyone lay out the pros and cons of this for me? Thanks.
Old 08-15-2007, 02:37 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
I changed my rearend fluid couple weeks ago. Now ford recomends using 75w140 in both front and rear.
Old 08-15-2007, 04:32 PM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
I'd go with the 75W140 - a toasted rear wouldn't be cheap to replace, or much fun either
Old 08-16-2007, 03:37 AM
aldridgec's Avatar
aldridgec
aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
I'd go with the 140. I tried 90 in mine once and though it was too light. Rear gets pretty warm, so I'd go with the thicker lube. There is a reason for it.
John with beastly 302
12-15-2012 08:25 AM
dieselsmoker
6.4L Power Stroke Diesel
11-18-2012 06:24 AM
Headviking
06-10-2010 07:58 PM
sadiebill
11-06-2006 10:53 AM
cravenc
1997 - 2003 F150
03-15-2006 07:55 AM
Quick Reply: 75W140 or 75W90
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
