Modular V10 (6.8l)
Drill V-10 air box?
Old Jul 25, 2002 | 10:58 PM
  #31
Hiexcur's Avatar
Hiexcur
Drill V-10 air box?
Has anyone found any best way to bring in more cool air into the k/n fipk or home mod from the front of the radiator. Bad idea?
Russell
Old Jul 26, 2002 | 01:53 PM
  #32
Monsta's Avatar
Monsta
Sit. Stay.
Drill V-10 air box?
Well, the ever popular ZooDad mod works. In fact, it is the only one that I've seen other than PSD stuff...
Old Jul 28, 2002 | 08:43 PM
  #33
daimon1054's Avatar
daimon1054
Drill V-10 air box?
NACA if you ever worndered where the went it is now called NASA
Old Jul 29, 2002 | 12:53 PM
  #34
Monsta's Avatar
Monsta
Sit. Stay.
Drill V-10 air box?
>NASA
HUH?
Old Jul 29, 2002 | 08:38 PM
  #35
daimon1054's Avatar
daimon1054
Drill V-10 air box?
NASA started out as NACA their work on airfoils (wings) for high speed flight and eventualy space travel was how the came across the NACA duct. It was the answer to getting cooling air into areas of a plane without drag or as little as possible. The reason you were wondering what NACA was is because before space flight they changed their name to NASA
Old Jul 29, 2002 | 09:19 PM
  #36
Monsta's Avatar
Monsta
Sit. Stay.
Drill V-10 air box?
AAAAAAAHHH!! Cool! Thanks!
Old Jul 30, 2002 | 03:27 PM
  #37
Gary E K's Avatar
Gary E K
Drill V-10 air box?
Monsta, were you having cooling problems?
:-X23 :-X12
Old Jul 30, 2002 | 03:57 PM
  #38
daimon1054's Avatar
daimon1054
Drill V-10 air box?
OK I looked at the inlet tube on the air box and it is strate and large almost as large as the throttle body, so to me there is no way cutting you airbox will improve performance. As stated above the MFG's have worked long and hard to reduce intake temp by moving the intake out of the underhood area cutting the box can not help.
On my vette every mod that works is a cold air induction unit same goes for old HIpo cars remember the shaker hood, cowlesp?) induction, ram air. Heat kills power and cutting you box has to increase heat.
Old Jul 30, 2002 | 04:22 PM
  #39
Gary E K's Avatar
Gary E K
Drill V-10 air box?
[updated:LAST EDITED ON 30-Jul-02 AT 05:25 PM (EST)]This is helping my V10
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=5613&.jpg
I just Cut a nice hole to give it more air.
Works for me.
Old Jul 31, 2002 | 11:02 PM
  #40
Hiexcur's Avatar
Hiexcur
Drill V-10 air box?
Gary E K thanks for the picture. Do you have any problem with moisture or water making its way in the air box?
I kind of did my own modification on the other side of the radiator brace cutting two 1 1/2" holes. I put them as low as posible to prevent direct water into the air box. I did trim the rubber skirt back a bit to let more air pass. I'll have to keep an eye on it when the wet weather comes around. It seems to be working, letting more air in?!?
Old Aug 12, 2002 | 03:18 PM
  #41
grmpfrog2's Avatar
grmpfrog2
Drill V-10 air box?
Gary- after looking at my '02 SD...your plan sure did look to be the best solution to getting more cool air to the filter. Cant imagine opening up the filter box to allow the HOT engine air sucked into the throttle body. But am stumped about best way to cut that hole in the radiator flange without taking off the grille. Any help?
Appreciate it-- thnx.....
Old Aug 12, 2002 | 05:07 PM
  #42
NoMo's Avatar
NoMo
Drill V-10 air box?
Take the grille off- makes it MUCH easier.
There's only a few screws along the top and some clips along the bottom to hold the grille in place. Comes off in less than 30 seconds.
Old Nov 22, 2002 | 08:28 AM
  #43
MNCamper's Avatar
MNCamper
Post Drill V-10 air box?
Does anyone here know the reason for the two nickel-sized holes in the stock air filter housing? I can see the paper element through the holes. One thought that I had was that they would be drainage holes for water that has somehow entered the airway, but they are too high up for that (they are at 8 or 9 o'clock when looking from the front of the vehicle -- that would be on an analog clock).
Thanks
2003 F350 Regular Cab XLT 4WD V10 6-Spd 3.73LS - Ordered 06-Sep; Received 14-Nov
Old Nov 26, 2002 | 09:26 PM
  #44
HiTech's Avatar
HiTech
Drill V-10 air box?
Interesting find - not sure mine has these. I wonder if the holes
are to give the truck a more agressive sound. They would reduce
intake resistance a bit, but also let in some power robbing warm air
when at temp. They could even be to tune the intake at certain engine rpms.
You could try taping them over and see if it drives/sounds any different.
-Jim
2001 E-450 V-10 Superduty
Old Nov 27, 2002 | 12:23 AM
  #45
R2's Avatar
R2
Drill V-10 air box?
Y2KW57
WTB - Parts & other
Jul 15, 2017 05:33 PM
BRay09
Jan 21, 2011 07:25 AM
doom899
Jan 31, 2009 04:54 AM
bob1987f
Dec 8, 2006 06:14 AM
MustangGT221
Oct 10, 2002 05:43 PM
