2003 SCrew F150...need brake suggestions
Old 08-09-2007, 08:47 PM
divejdt's Avatar
divejdt
divejdt is offline
Arrow 2003 SCrew F150...need brake suggestions
Hello
I have a 03 super crew f150 and the oem front brakes have warped again. I am just starting my search for replacement rotors and pads. Has anyone found that "perfect" combination. I dont know if I should get cross drilled, cross drilled and slotted or just slotted.
tx for look'n
James
Old 08-10-2007, 06:31 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
yes!
Brembo OEM replacement rotors (no slotted, no holes, straight up disk) and Hawk LTS pads....i have them on all four wheels on my 01 and i love them.
Old 08-10-2007, 07:59 PM
ReAX's Avatar
ReAX
ReAX is offline
I'll second no drill/slot, but the rest would depend on budget and drive type. Baer makes some really nice kits, SSBC has some nice calipers, and Performance friction makes the best set of stock replacement rotors I have held. DBA also makes some nice rotors. Anything directional will be better than OEM.
Just remember to bed the rotors and depending on pad selection, some need to be burned in. Performance Friction doesn't, and their Z-rated pads are very nice.
Just for some back ground. I have used powerslot/autospecialities for a while (10 years). I also have hawk pads right now. However, I have a request in for Performance friction rotors and Z-rated pads, my PF rep is working on it for me.
Old 08-11-2007, 08:43 AM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
Old 08-12-2007, 11:03 AM
divejdt's Avatar
divejdt
divejdt is offline
Thanks for the help
Thanks for the help, I have read that some people have heard some grinding noise with drilled/slotted. I am trying to stay under 400.00 for new rotors and pads. What do you think about cryo-genic (sp?)treated rotors?
James
DISLFVR
10-15-2012 09:12 PM
choochoof150
2004 - 2008 F150
01-01-2011 03:30 PM
melek4me
2004 - 2008 F150
02-17-2007 10:45 PM
claw302
1999 to 2016 Super Duty
08-01-2005 01:10 PM
Quick Reply: 2003 SCrew F150...need brake suggestions
