Filter Numbers
Old Aug 13, 2007 | 11:17 AM
EZ-Ford's Avatar
EZ-Ford
Lightbulb Filter Numbers
Having searched many threads, I would be really nice to have a single location that lists the part numbers of all the filters needed. Once updated, can this then be moved to the Tech Folder.
I'll start: Others add as you know (Beachbumcook, you usually have a good collection of these).
Ext Transmission:
.....Motocraft.......FT-145
.....WIX...............57702
Int Transmission:
Fuel Filter:
.....International...1847170C92 (includes both filters)
Oil Filter:
.....International...1840752C91
.....Oilguard.........PF-L2016 (do not use #2016)
.....Fram.............CH9549
Others add to this list.
Old Aug 13, 2007 | 06:24 PM
bismic's Avatar
bismic
Ext Transmission:
.....Motocraft....... 3C3Z-7B155-BA
Int Transmission:
Fuel Filter:
OR........1847170C93 (includes both filters)
.....Motocraft....... FD-4604
.....Motocraft....... 3C3Z-9N184-CA
Oil Filter:
.....Motocraft......FL-2016
.....Motocraft......3C3Z-6731-AA
Old Aug 13, 2007 | 07:23 PM
97F350PowerStroke's Avatar
97F350PowerStroke
what is the difference between the two motorcraft numbers...?I have always used FT-145, FD-4604, FL-2016 on an 04 6.0
Old Aug 14, 2007 | 04:28 PM
Beerstalker's Avatar
Beerstalker
I believe that the 3C3Z part numbers are actually Ford part numbers not Motorcraft.
Also a note on the International part numbers. Just give them the first seven digits, ignore the C and the two numbers after it. They just stand for the change level. These numbers will change every now and then and the parts guy will just give you whatever the current one is when you give him the first 7 digits. For example if you go in and give the parts guy the number 1840752 today you will most likely get the C91 version, but a month or two from now you may get a C92 or C93.
Old Aug 14, 2007 | 04:51 PM
EZ-Ford's Avatar
EZ-Ford
Thanks all. So the list we have so far is:
Does anyone have the MC or Ford Air or Internal Trans filter part numbers?
Ext Transmission:
.....WIX..............57702
.....Ford.............3C3Z-7B155-BA
Int Transmission:
.....Ford..............
Fuel Filter:
.....International...1847170xxx (includes both filters)
.....Motocraft.......FD-4604
.....Ford..............3C3Z-9N184-CA
Oil Filter:
.....International...1840752xxx
.....Ford.............3C3Z-6731-AA
Air Filter:
Old Sep 6, 2007 | 10:52 AM
EZ-Ford's Avatar
EZ-Ford
Anyone have the missing part numbers above?
Old Sep 6, 2007 | 11:00 AM
1ReDNeCK's Avatar
1ReDNeCK
Internal trans filter - Ford part # 3C3Z-7A098-AA MC # FT-144 - Air filter - Ford part # 4C3Z-9601-AA - MC # FA-1778
Old Sep 6, 2007 | 11:10 AM
Beerstalker
Looks like we have everything now. Could one of the moderators add this to the tech folder?
Air Filter:
.....Ford.............4C3Z-9601-AA
.....Motocraft......FA-1778
Fuel Filter:
Oil Filter:
Transmission (Eternal):
Transmission (Internal):
.....Ford..............3C3Z-7A098-AA
.....Motocraft.......FT-144
Old Sep 6, 2007 | 11:20 AM
EZ-Ford's Avatar
EZ-Ford
Thanks all for the updates. This is what I was hoping for, all in one place. Print this out and keep it in the truck, that way no questions when you get to the parts counter (or store) as to what you will be getting.
Old Sep 7, 2007 | 03:16 PM
Fordnewbe's Avatar
Fordnewbe
If you go online to www.dieselfiltersonline.com there is a good cross reference listing of filters for diesels. Click on 6.0 and then the filter you want to look for.
Old Sep 7, 2007 | 07:35 PM
LvTitan's Avatar
LvTitan
since we're on the subject of filters ? does anyone know the part numbers to reference for the FASS ?
i'd like to get the 3 micron hydro/fuel filter and the water separator, i have access to
Baldwin filters for free through work, but dont know what the matching part numbers would be.
Old Sep 7, 2007 | 09:14 PM
dougc's Avatar
dougc
I know its not a filter, but how 'bout adding the part number for the replacement water drain plug (replaces the 6mm allen wrench plug)? I'm printing this and putting it in my truck.
Old Sep 8, 2007 | 09:14 AM
burninfilm's Avatar
burninfilm
Here are a couple of others if interested.
Oil : O'Reilly's microgard # GL 45515
Ext. Trans: Baldwin # P7247
Old Sep 8, 2007 | 11:42 AM
PowerStrokeHD's Avatar
PowerStrokeHD
HFCM Drain Plug...
IH - 2589259
Ford - 6E7Z-9C082-A
A few more filter numbers...
Baldwin fuel filter - PF7812 KIT
Baldwin internal trans filter - 20005
Baldwin oil filter - P7235
Old Sep 9, 2007 | 09:13 PM
dougc's Avatar
dougc
thanks for the part no.
F-250 WARHORSE
Feb 15, 2015 09:13 PM
Outlaw56
Sep 10, 2013 05:16 PM
gwpowell
May 8, 2009 06:02 AM
pcguy760
15
Sep 6, 2005 12:55 PM
87 b2
Bronco II
Dec 6, 2004 08:25 PM
