Should I worry?? -after changed sparks-
Approx 1.5 week ago i changed the spark plugs with correct TSB part # for sparks. I followed the TSB direction, I used PB bottle spray and i used VERY LITTLE i say 1-1.5 sec spray each of sparks. It went smooth.
I did read some of here said to be expect some white smoke out after PB or whatever guys put it in to loose up sparks when to start up.
I was not really pay attention to rear end after start up motor also have private glass rear window. Today my wife said she see some puff white smoke came out then few seconds later its all clear fumes.
I couldnt remeber before changed the sparks if theres quick white smoke when start up motor.
No engine light, nothing funny sounds, its all normal running engine.
After i started up again, wife said its much less puff white and i ran to rear and i could smell a little bit of PB/gas..
I guess it will take time for PB to wear off from engine ?
Should I worry ??
Any tips or advice will be great...
thanks!
YOMAN!
Should I worry ??
thanks!
YOMAN!
Kenneykole
08-22-2012 07:51 PM
