Carb questions
Old Aug 10, 2007 | 07:34 PM
65f100_352's Avatar
65f100_352
Carb questions
What would be a good carb choice for a 78 F250 with a 460 that wont bog out? I have thought about the autolite 4300.
Old Aug 11, 2007 | 06:45 AM
LxMan1's Avatar
LxMan1
That may be ok, I used the Edelbrock on mine.
Old Aug 13, 2007 | 03:28 AM
65f100_352's Avatar
65f100_352
did it bog out any?
Old Aug 13, 2007 | 07:40 AM
LxMan1's Avatar
LxMan1
Nope, no problems. I ran the 750 on mine. I had a mild cam, headers, true duals and a Performer intake. It also runs well with a 600 Holley.
Old Aug 15, 2007 | 12:20 AM
Critter183's Avatar
Critter183
Been a while since I played with carbs but the biggest reason for bogging out as you put it is too much carb for the engine.
There's a formula for calculating required carb CFM.
CFM = Displacement (in cubic inches) X Maximum RPM / 3,456
302 CI X 6000 RPM = 1,812,000 / 3,456 = 524 CFM.
Just go up to the closest available size and you're there.
Old Aug 17, 2007 | 03:29 AM
65f100_352's Avatar
65f100_352
Ok, I meant choke out from a steep angle instead of bog. I like going up some pretty steep stuff, and i dont want my truck to choke out in the middle of a hill. BTW, has anyone use a carter thermoquad off road?
Old Aug 17, 2007 | 12:40 PM
kermmydog's Avatar
kermmydog
Smile
Yes, on an 85 W250 Dodge 318. There's not any different than a Q-Jet off-road. The problem is finding a good Thermo-Quad, and getting it set up. With plastic bowls they had there problems. Many Dodge guys go to Q-Jets. If you check out the forum at allpar.com you'll find a good group of Dodge people if you search there is a lot on Thermo-Quads there, & where to buy good ones. Holley builds the Truck Avenger that is designed for what you want. 45 degree side angle Holley claims NO PROBLEM. Spring loaded needle & seat. Never used one. I run a 600 CFM 4160 Holley on my 86 F250, 4x4, 460.
Old Aug 17, 2007 | 03:47 PM
LxMan1's Avatar
LxMan1
A truck avenger then would be my choice. 670cfm
Old Aug 19, 2007 | 08:08 PM
65f100_352's Avatar
65f100_352
Id love to use a truck avenger, but i dont have the money for one. Back to my original question, would a 4300 do ok off road, going up steep stuff and mudding?
Old Aug 19, 2007 | 11:57 PM
LxMan1's Avatar
LxMan1
It should do ok since the float extends on both sides.
65F100390
Nov 1, 2010 10:03 AM
baracade
28
Jun 29, 2010 03:29 PM
old_man_winter
Sep 21, 2006 04:35 PM
sped01
Oct 27, 2002 06:50 PM
David
19
Jan 29, 2000 08:01 PM
