Offroad & 4x4
Eagle Alloys Wheel Question
Old 08-10-2007, 01:09 AM
Nightrain's Avatar
Nightrain
Nightrain is offline
I bought a set of 15x8 Eagle 058's awhile back and they had a sticker on them that said to not run a bigger tire than a 32" O.D.
That got me curious...
Why do they suggest to not run a bigger tire than that? Is the wheel diameter too small, too narrow?
This is the first set of wheels that I've bought, and it threw me off a bit.
Thanks!
Nightrain
Old 08-10-2007, 07:04 AM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
it's insurance and liability. same reason automakers put stickers on the sun visors about putting your seatbelt on and the sticker on the hair dryer that states not to use in shower/bath!
kubota was running 44 tsl's on his eagle alloys up until he bought his double beadlocks not too long ago!
-cutts-
Old 08-10-2007, 02:02 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
What I have noticed between ones (15" rims) rated for 31s and ones rated for 35s, by the OEM, is the lip from the bottom of the bead to the outside edge is a tad longer and thicker.
Also, I have noticed the shape of the bead area is different between steel rims and aluminum rims, though that may have been an OEM difference since I was comparing rims side to side from different OEMs.
Also, the ones for 31s had a max of only 41 psi, which was kind of useless considering most of the LT C rated 15" tires run to 60 psi.
Old 08-10-2007, 03:26 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
fishy has it right, they put that on there, so when you put a set of 35s on them and go thrash the truck and destroy a rim they can deny warrenty claims and basically tell ya it's your problem
Old 08-11-2007, 01:49 AM
Nightrain's Avatar
Nightrain
Thanks, guys.
I was just wanting to make sure that it wasn't on there for a REAL purpose!
Nightrain
KIKKUP
11-23-2013 11:03 AM
94WhiteF250
04-01-2011 01:53 PM
Chuggster
1999 to 2016 Super Duty
11-11-2010 05:35 AM
clc900
12-16-2009 12:21 AM
kabcpapc
01-23-2005 09:39 PM
Quick Reply: Eagle Alloys Wheel Question
