Filling Body Seams?
Originally Posted by Kurt G.
I read on another thread that a copper pipe flattend out would also work as a backing. is that correct? Kurt G. Y-blocks rule.
I spent $20 (I think) for a "welder's helper" from Eastwood. It is just a copper plate with a wood handle. Works great.
My local welding shop only rents the bottle, it's like 4 bucks a month.
Get the Bottle, You'll be sorry if you don't, I started my project without the bottle and when I got the Bottle, and changed over to Mig Gas and welded.. It was like I got hit with a 5 Gallon of V8 juice.. " I Should have gottent he bottle from the begining".
I also have a lincoln 110 mig welder, I love it.
My 56cents worth.
My 56cents worth.
Welding seams is the cat's ***. Be sure to use a bernz-o-matic and a razor blade to clean the factory sealer out of the seam to avoid polluting the weld. I also welded all the seams including the rear fenders to the bed, if you like long smooth panels you'll love these mods.Good luck and get the gas
Check with your welding supplier about renting or leasing the tank, don't buy it. I lease 8 tanks of various gasses for my business and garage. Don't make the mistake of getting one of the small cylinders the refills will kill any savings. Shielding gas is the only way to fly with a wire feed for body work, the flux core wire is too thick for sheet metal. I just filled the louver panel on Gracie, The front edge that butts to the hood had been ground thin originally so it kept wanting to blow thru. I made an 18 ga V shaped reinforcing strip for the inside of the joint that I plug welded in place then cut open the corner and welded in an 1/8" rod to make a nice clean solid corner.
Received 4,130 Likes
on
#28
#30
I have used copper pipe flattens out for backing and it works great. I try to use that method any where I can get the copper clamped into place.
