59 f100 poly gas tank?
Old 08-06-2007, 09:08 AM
MN59f100
MN59f100 is offline
MN59f100 is starting off with a positive reputation.
Question 59 f100 poly gas tank?
Does anyone know where I can get a plastic or fiberglass gas tank for a 1959 F100 that would go behind the seat? I only seem to be finding steel ones.
Old 08-06-2007, 02:06 PM
53fatfndr's Avatar
53fatfndr
53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
LMC has tanks, but they don't say if they are made of steel or poly.
http://www.lmctruck.com/icatalog/fb/0085.asp
Old 08-06-2007, 04:25 PM
1959f14x4's Avatar
1959f14x4
1959f14x4 is offline
1959f14x4 is starting off with a positive reputation.
LMC they are steel
Old 08-06-2007, 09:24 PM
MN59f100
MN59f100 is offline
I saw those at LMC and I thought they were steel. The search continues....
Thanks
Old 08-07-2007, 09:05 AM
OldgreenF1's Avatar
OldgreenF1
OldgreenF1 is offline
OldgreenF1 is starting off with a positive reputation.
I dont think there is an in the cab tank made in poly or glass, its probably a liability issue. Something to do with changing from steel to something else could end up in a lawsuit I would think since its inside the cab.
Old 08-07-2007, 07:05 PM
ditz
ditz is offline
ditz is starting off with a positive reputation.
I have had only 1 poly gas tank but had 2 seperate leak issues with it and **** canned it. I didn't even try to sell it because of the danger it posed. The poly tanks may be great but I will never own another. The first leak started about a year after the first gas was introduced. I found some special glue to patch it and put it back into service. About 6 weeks later another leak started in a different location than the first. It was not worth the risk to patch again.
Old 08-08-2007, 02:14 PM
MN59f100
MN59f100 is offline
Thanks everyone for the information. Where did you get the poly tank for the 59?
78 & 87 Super Cab
02-26-2014 06:15 PM
johnmel59
09-03-2013 09:27 PM
Jake59lighting
09-08-2009 10:27 AM
steves59f100
10-21-2004 10:31 PM
youdog99
05-09-2002 10:55 PM
Quick Reply: 59 f100 poly gas tank?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
