Show/Tell us your interior storage ideas in a SCRew
One thing I really dislike about the 07's is the lack of interior storage, especially in the King Ranch which has the space wasting floor shifter with a measly console.
The overhead rail system is a joke (not paying $50.-100 for a plastic jewelry size box !). Is there an after market setup for the rail system ?
No room under the front seats because of all the wiring for the electric seats.
What have you done to increase storage of items in your supercrew, including removal of the back bottom seat(s) ?
PS: I'm not interested the overpriced piece of plastic junk called the DU-HA !
What are you storing? I have an 06 Super cab with the console and think there is plenty of room under the rear seats for a lot of little odds and ends and the console has quite a bit of space. The door panels also have quite a bit of space.When all else fails there is a very large area behind the rear window !
Well I know I wish that ford would have put a tray or something in the center console.
I like the center console but dislike the garbage can where all the small stuff ends up on the bottom and you gotta dig everything out to get something out of it.
I too miss the underseat storage of my dodge. But I found a plastic bin at wally world.
I dont remember the size but it fits nicely under the rear seat of a crewcab on the drivers side and is just long enough that it goes to the center hump under the seat. It actually works good, but tends to slide out a little bit every now and then. Im thinking of putting some velcro strips on it to see if the carpet will hold it in place.
The down fall...its not under the front seat and easy to get to.
Hope that helps a bit..
Well the 97 Supercab I had had the console with the column shifter. It not only had more storage, you could lift out the cupholders and there was a hidden compartment where you could hide items. There was also room in front of the console where I put an aftermarket console. It seems like the 07 has a bigger interior with less space !
Throw it in the back seat floorboard, and cram it under the back seat!
Seriously, I've thought about one of the DU-HA things. I just can't justify spending that much for a plastic/rubber bin to go under the back seat. I'm thinking about building something to fit under the back seat, just to kinda keep the clutter from spilling out into the back floorboard!
supermag
supermag
Why does it have to be in the cab?
How about this? http://www.truckaccessoriesinsider.c...organizers.htm
This is what I use for extra storage.
Originally Posted by SDTruckMan
HOLY CRAP .... Whered you find that...Awesome.
This is the second unit I've had. There was one on my '04 STX also.
Well I know I wish that ford would have put a tray or something in the center console. I like the center console but dislike the garbage can where all the small stuff ends up on the bottom and you gotta dig everything out to get something out of it.
Originally Posted by FoundOnRoad
I found a small plastic center console at ChinaMart that fits into my center console fairly well. It has a couple of cup holders where I keep my cell charger and Leatherman. A change holder that holds a cigar tube and a Maglite. A cassette / CD holder that holds a dozen slim cased MP3 CD's. A pencil holder for the anything long. And there is enough room to put a small compact umbrella next to it, with room either in front of or behind (depending on placement) to spare. I just hope it wasn't colored with lead pigment.
I thought it might be worth it, but wasn't sure.
