Ford Ranger 4R44e trans shifting problems
only thing the tranny shop said is if they rebuild it they would put in a better shift kit.
the fluid is brown and i realize there would be some friction plate material in the bottom of the pan. they just dropped the pan and changed the filter and inspected the bottom of the pan. no wheelchair sports here, getting to old and have worn out my shoulders.
What kind, size, & how many metal particles, other than the clutch material, were in the pan????
Dropping the pan to change the filter & refilling the pan, only got about 1/4 - 1/3 of the old oxiized fluid out of the system, as most of it remains in the valve body, torque coverer & cooler lines, so I suppose it's better than doing nothing, but not much better, because the add pack of the new fluid will be used up quick, having to deal with all that remaining old oxidized fluid, & tryng to clean up all the gum, varnish & sludge thats likely to be in the valve body, solenoids, cooler lines, ect.
It's likely to need some help imo, so I'd really consider adding the Seafoam Trans Tune & driving it about 100 miles or so & see if things get better. If so, maybe drive it a little more, until it stops acting out, or until any improvement stops, then have a FULL fluid pump out/exchange done & see if that will last.
If you don't get any improvement with the Trans Tune & ALL new fluid, then it'll probably be fix it time.
The Seafoam Trans Tune can be had at most auto parts stores, for about $7 a pint & if your fluid was brown like you said, then I'd probably use the whole pint of Trans Tune!!!!
The shift kit the tranny shop was talking about, was probably the TSB on the valve body. There is a article on it in the "Tech Info thread, if your interested.
Let us know what you do & how it goes.
#30
