where does this go ?
Old Aug 4, 2007 | 06:56 PM
B1GKAHUNA's Avatar
B1GKAHUNA
im changing the ac comp/evac/accum/orifice tube-where does the tube go ??? also where does the oil go ? this is for my 94 f150 xlt excab 5.0
Old Aug 4, 2007 | 09:07 PM
73F100*8Mile's Avatar
73F100*8Mile
Evac? You mean evaporator? Is it damaged? The tube will be in the high side line going towards the evaporator, towards the black box on the firewall. You need to be extremely careful when removing it if you do not have the proper tool. If it breaks off in there then you're screwed. Spray penetrant in the high side line towards the oriface tube when you get the system opened and let it soak for a while, get some crackers and a drink and then come back and soak it again. When installing the new one, oil up the two o-rings and slide new tube into the line until you feel it seat. Your compressor will take about 3 ounces of oil, 2 in the evap, 2 in the condensor and 1 in the dryer. Good luck and take your time!!
