yoke torque spec
Old Aug 4, 2007 | 11:44 AM
faststang94's Avatar
faststang94
yoke torque spec
just wondering if anyone has the correct torque spec for the yoke so i dont over tighten the crush sleeve. this is a 10.25 rear end
Old Aug 4, 2007 | 09:06 PM
catfish101's Avatar
catfish101
are you building it from scratch or fixing an oil leak or yoke replacement?
Old Aug 5, 2007 | 12:07 AM
faststang94
none, its just loose and i tightened it with my 1/2 wratchet but i didn't get it tight enough because now i have a vibration again. i know theres suppost to be torque specs for how tight you need to get it, i just can't find it.
Old Aug 5, 2007 | 06:17 AM
PLC7.3's Avatar
PLC7.3
If it came loose think new seal, crush sleeve and nut........My manual states 160 Ftlbs........ sending it now.
Old Aug 5, 2007 | 03:35 PM
Franklin2's Avatar
Franklin2
Next time you work on it, pull the yoke completely off and look at the splines on the ID. I just worked on one for the same thing, and noticed the splines were worn. I am suspicious that the splines being worn are letting the yoke work back and forth on the shaft, which loosens the nut. The owner didn't want to spend the money for a new yoke, so we tightened it as tight as my impact would go, but if it works loose again, I think my theory is going to be correct.
Old Aug 5, 2007 | 03:55 PM
faststang94
ya thats what i thought too about the splines beeing warn. it was a farm truck and it was beat pretty hard. when i tightened it up it was ok for a day, but i did not torque it to 160ft lb ill pull it off this time and take a look, but right now i don't have the time to work on it so i think ill just put some blue lock tite on it and tighten to spec and hope it stays.
Old Aug 5, 2007 | 03:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The yoke splines do wear, and fortunately the yoke wears before the pinion shaft splines.
That makes the repair a lot cheaper than it could be if you needed to replace the pinion.
Old Aug 5, 2007 | 10:15 PM
catfish101's Avatar
catfish101
You have to be carefull on hammering these yokes pn. It will pull the pinion gear into to ring gear and mess up your ring and pinion mess pattern and it will most likely not live very long. Boom.
Benchwrench
May 11, 2016 02:45 PM
ARK-F150
1978 - 1996 Big Bronco
Dec 20, 2015 07:15 PM
aidandj
Dec 12, 2015 07:44 PM
montego69
Jan 17, 2014 09:57 PM
BlackDiesel85
Aug 18, 2011 10:53 PM
