Gotta brag about my mileage
Just made a trip up to Bowling Green, KY from Jefferson, GA, 367 miles. Used the AC from Jefferson to Mont Eagle, TN then ran with the windows down. There was just one in the truck and about 300 pounds in the bed. I got 19.91 mpg.
Then on the return trip I ran from BG, KY to Chattanooga with the AC and then from there to Jefferson with the windows down. Same payload but now two in the cab and I got 19.92 mpg.
I used the cruise control set at 74, roughly 2000 rpms, most of the time. There was very little traffic while I was driving so I drove at a very consistent speed.
I've got an '06, 2WD with the 5.4L and tow package
i just got a little better than 20 with my truck going from PA to NC...i went a little slower than you and i had 3 other people other than me in the truck with the bed full (about 300 lbs) and the 4 of us were about 650 lbs...so total aroud 1000 lbs...
i was very pleased with it.....i'm very easy on the skinny pedal too...that helps out....i'm usually into OD by 40mph
UKkid im from jefferson too i made a trip to orlando a little over 500 miles and had mine set on 72 the whole way and got 21.7 mpg and it was me and my g/f and ALL her stuff for the 5 days we were down there which was probably 300lbs of shoes alone but what im trying to say is i was suprised with the mpg not to bad saying my dads dodge 1500 with the 390ci in it only got 13.6
Originally Posted by wedge88
Do you guys getting this higher mileage have tuners? My 06 SCREW FX4 will run around 3000RPMs at 74mph. I have to stay around 65 to keep RPMs at 2000. I usually get 13-14mph at best
Did you adjust your speedo for your taller tires? And 3000 RPM sounds like alot even if you have 3.73 gears... goin to 305's like your gallery says would put you bellow 3.55 i bet
