Need help! Diesel keeps stalling....
Old Jul 31, 2007 | 02:15 PM
bjaworski's Avatar
bjaworski
My 2002 F250 7.3 keeps stalling on me. I have replaced the fuel filter and it still happens. The funny thing is, is that is will go in spurts. I will jerk 2-5 times while driving one day/stall while at an intersection at idle or run fine for 3-7 days without a problem. I thought maybe it was the fuel filter but that didn't do it. It did stall right after I replaced the filter and I could hear the gas being injected. It also always starts back up without any problems and runs fine. I am guessing maybe water in the lines or a fuel pressure problem? I look forward to your suggestions.
Old Jul 31, 2007 | 02:17 PM
af4ms's Avatar
af4ms
Cam Position Sensor would be the first place I would look. Around $25.00 for the new version.
Doug
Old Jul 31, 2007 | 02:19 PM
badblueoval4life's Avatar
badblueoval4life
cps sounds good to me as well!!!
Old Jul 31, 2007 | 02:24 PM
bjaworski's Avatar
bjaworski
Thanks, I will look into that soon!
Brent
Old Jul 31, 2007 | 02:36 PM
F250_'s Avatar
F250_
When you buy it, go ahead and get two of them and keep the second one in your glove box as a spare for cheap insurance and "stranded" prevention.
Old Jul 31, 2007 | 03:18 PM
ryaneverk2's Avatar
ryaneverk2
Welcome to FTE, Brent.
I agree... CPS!
Old Jul 31, 2007 | 03:35 PM
haulingboat's Avatar
haulingboat
CPS stands for Cam Position Sensor. They go bad often. You can replace it yourself in less than 30 miutes.
Old Jul 31, 2007 | 03:41 PM
clintbonnie's Avatar
clintbonnie
Here is the new part number.. new design...
http://fordparts.com/cart/?pn=F7TZ-1...&submit=Search
Old Jul 31, 2007 | 03:56 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
And here is how to change it.
Need fries with that?
http://guzzle.rbmicro.com/cps.html
Old Jul 31, 2007 | 04:01 PM
clintbonnie
It is so Easy, a Cave Man can do it ! (nothing personal to any cave man that might be reading this)
Old Jul 31, 2007 | 04:05 PM
af4ms's Avatar
af4ms
Yea, just a pointer, use a socket instead of a wrench. It is not hard to round off the shoulders of the bolt with a wrench.. This caveman has experience rounding things off.
Old Jul 31, 2007 | 06:43 PM
guitarpicr's Avatar
guitarpicr
Ugh-Ugh Caveman for CPS- Good Luck!
Old Jul 31, 2007 | 07:49 PM
JOE-M's Avatar
JOE-M
Brent
You better look into it real soon. One of these times it won't start back up and you'll be on the side of the road broke down.
Joe
Old Aug 1, 2007 | 06:00 AM
bjaworski's Avatar
bjaworski
Thanks for all the great information! You all have been really helpful. Hopefully this does the trick. Did you say the part is around $25? I went to autozone yesterday and they told me $150? I guess I should order it from Ford, huh?
Old Aug 1, 2007 | 08:01 AM
af4ms's Avatar
af4ms
DON'T get the aftermarket. There is a high failure rate on the aftermarkets. I put one in my truck and it was bad out of the box. If you go to the stealership they "may" have the "B" version in stock. If they have the original they will want probably 180 to 190 for that one. They are trying to push those to get them out of their inventory. If you can't find it at the stealership then order it from one of the links above.
