Illinois Chapter Join Chapter Leader: wpnaes
Axle travel
Old 07-15-2007, 10:25 AM
illinois4by's Avatar
illinois4by
illinois4by is offline
Axle travel
My dana44 axles have a bit of travel (in and out that is) how much travel should i have if any at all? I do get a rattle in the front end. Ive checked and everything is tight but the axles. I was wondering if the c-clips in my diff came out? Any ideas. Oh and Im experimenting with my 300-6 if all goes well i should get around 500hp out of it by theory. Ill keep you updated.
Old 08-02-2007, 11:49 AM
amish77's Avatar
amish77
amish77 is offline
If the clips come out then you're fubar. The axles will slide out of the tubes. There's probably something else in the pumpkins that's a little loose.
Old 08-02-2007, 01:46 PM
Rev Den's Avatar
Rev Den
Rev Den is offline
How much travel?
more then a "feel" and I would pull the cover and check the center pin for wear.
Rev
checksix
06-10-2013 06:59 AM
robinma
04-08-2011 07:19 PM
49willard
15
02-02-2006 10:25 AM
branpollard
12-26-2004 03:43 PM
Quick Reply: Axle travel
