Ranger & B-Series All Ford Ranger and Mazda B-Series models
diesel rangers?
  #31
Old 08-16-2007, 12:06 PM
02Taco
02Taco is offline
02Taco is starting off with a positive reputation.
Originally Posted by 99F150
You have to be a little carefull here. One reason they only made 59HP and 86 HP new was they use an allumium head that is weak. Start making too much HP and it will break due to torque going through the roof.
Are these the only diesels you can swap in the ranger? They seem very weak 86HP and 134TQ was the highest rated on on the (http://www.therangerstation.com/tech...ry/Diesels.htm) list. Wouldnt you be better off with a 3.0 150HP 180TQ? Or is there a more modern version that anybody has swapped/imported?
  #32
Old 08-16-2007, 12:16 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
how about a cummins 4bt out of a dodge? Same as the 6bt I just got out of a 250 ram pickup - going in my 74 crew cab 4wd.
The 4bt is an inline 4 with a turbo. Jeep guys do the swap as they are smaller than the inline 6 (6bt) and put out good power.
Technically it's not a "dodge" motor since Dodge contracted cummins and the motors are in blue bird busses, box vans, etc.
The only catch would be passing smog. But if you already have a ranger diesel title chances are you don't have a smog check needed.
  #33
Old 08-16-2007, 01:50 PM
David85's Avatar
David85
David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
I don't think the prekins had an aluminuim head did it? But even if it did, its not as bad as you might think, the only real danger is overheating which can warp it. Even if the head bolts can't cope (and I think they could), theres always thread in heat studs.
86 Hp sounds bad, but the 2.3 turbo will churp the tires, even in second gear sometimes, and I'm pretty sure that it can be built up, but most of the peops that have done it don't speak english! So gleaning info can be complicated.
The real limiter is when the wastegate opens, The engine can put out more than 86 Hp, but since its new I want to learn more about it before pushing my luck.
I did see a cummins 4bt in an explorer once, but that sucker is HEAVY! What was nice about the 2.3, is that it lined up the suspension perfectly after is was dropped in. In argentina, the ford superduty (they call it the f100 or f200) is actually offered with a cummins 4cyl, rated at over 200 horsepower.
  #34
Old 10-09-2007, 06:25 PM
ridemypanhead
ridemypanhead is offline
ridemypanhead is starting off with a positive reputation.
Hello,
I am looking for anyone that has a diesel Ranger 1982-1984. I want to swap my 4 speed trans with a 5 speed from my 1983 MazdaB2200 diesel which has a diesel.
Any thoughts?
  #35
Old 10-09-2007, 07:18 PM
fordpickup292v8
fordpickup292v8 is offline
fordpickup292v8 is starting off with a positive reputation.
Originally Posted by ridemypanhead
Hello,
Any thoughts?
It should swap over just fine. Only thing is the ranger is alot heavier than the B2200 and may having a hard time pulling the Ranger in fifth. Mine has a hard enough time with the 4 speed. Good luck.
  #36
Old 10-09-2007, 09:06 PM
16diesel
16diesel is offline
16diesel is starting off with a positive reputation.
any one know where i could find a 4x4 stndard shift 2.3 turbo diesel ranger do u?
  #37
Old 10-09-2007, 09:17 PM
David85's Avatar
David85
David85 is offline
These trucks are pretty rare, and finding them is gettng harder all the time. The donor truck that we used for our conversion was trashed to say the least, rusted out and all the glass was smahed.
So far I've only seen two other diesel rangers on the road, and chances are they're not for sale either. One of them looked like a restoration, and the other was used for towing a flatbed trailer. Both were long box, reg cabs (even the donor was).
Form what I can tell either no one bought the auto version or it was never offered with it from factory to begin with.
I have seen the odd one on Ebay, even a ram50 diesel, which uses the same engine.
  #38
Old 10-10-2007, 10:00 AM
07F1504x4
07F1504x4 is offline
07F1504x4 is starting off with a positive reputation.
Ford makes a 3.0 Diesel for the South American and Austrailian Ford Rangers...They are the same trucks except they are optioned with a crewcab or diesel unlike its American counterparts...Ford should sell it here...i'd buy one!
  #39
Old 10-10-2007, 10:25 AM
rangerfan's Avatar
rangerfan
rangerfan is offline
rangerfan has a very good reputation on FTE.rangerfan has a very good reputation on FTE.rangerfan has a very good reputation on FTE.rangerfan has a very good reputation on FTE.
Me too, 07F1504X4. Maybe someday the Ford Motor Co will make what its customer base really wants. I won't hold my breath though.
  #40
Old 10-10-2007, 10:27 AM
07F1504x4
well from what i heard and understand after 08 Ford is stoping production on all Rangers...but i may be wrong, so i wouldnt hold my breath either.
  #41
Old 10-10-2007, 11:13 AM
David85's Avatar
David85
David85 is offline
You guys are not alone in wanting the diesel ranger in north america, but the EPA is on a witch hunt against diesels at the moment. Manuafurers will probably close the gap eventially, but as it stands right now, the engines are getting less efficient due to all the emissions crap, and the fuel has less energy in it to make it burn cleaner (side effect of making ULSD). Spend some time on the 6.4L diesel forum to get an idea of what can be expected.
The ranger down under is avalable with two seperate diesels, a 2.5 turbo and a 3.0 turbo, I don't think they even offer a gasser over there .
The same basic truck is avalable in europe and south america as well, basically anywhere but here .
Its rated for 7000lbs worth of trailer (same as my f150), and comes with a close ratio 5 speed manual, some say they can go past 30 mpg. In the UK, they are avalable with a hydraulic tilt steel utility bed as well. I guess ford just doesn't take the ranger seriously around here.
  #42
Old 10-11-2007, 04:55 AM
captaingofast's Avatar
captaingofast
captaingofast is offline
captaingofast is starting off with a positive reputation.
An `87 diesel Ranger just sold on ebay for $4800. Here's the auction #:
280158625435
I talked to a Ford engineer yesterday who works at the Oakville, Ontario plant. He says 2008 is definitely the end of the line for the Ranger. He has no idea why they're doing it either.
Maybe they want to bring the Edsel back and need the 'Ranger' name for that. Wouldn't surprise me.
  #43
Old 10-11-2007, 08:32 AM
99F150
99F150 is offline
99F150 is starting off with a positive reputation.
280158625435
How does one get the opportunity to talk to an engineer?
  #44
Old 10-11-2007, 09:23 AM
captaingofast
I sold him an old JD 212 I restored. They must pay well at Ford. He paid full price and bought it over the phone.
  #45
Old 10-11-2007, 01:23 PM
ChaseTruck754
These trucks come up on eBay from time to time. I've seen 4 recently. Not common by any means but they are there. I just need to find one that I don't have to have shipped across country.
That, or find a title somebody is willing to sell. At least those can be shipped across country - haha
Quick Reply: diesel rangers?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
