91 2.3 spark, no fuel,
Old 08-26-2007, 11:18 AM
68 351 bronc's Avatar
68 351 bronc
68 351 bronc is offline
The 91 is a Mustang, not a Ranger. I have good spark and good fuel pressure at the injector rail, but engine will not fire or run. When I pull a plug after cranking on it a bit the plugs are dry. How do I check to see if the injectors are getting a signal to spray? If they are not then where do I look first? I bought the car from a guy who knows nothing about cars. He says it got hard to start but would run good once started. He drove it until it quit starting all together. I checked the AIC and the EGR and neither were stuck open. It has the DIS ignition.
Thanks, Ed
Old 10-19-2007, 01:20 AM
fordman26's Avatar
fordman26
fordman26 is offline
check the crank shaft position sensor this may fix your prob. fordman26
Old 10-19-2007, 04:31 PM
68 351 bronc
Thanks, I got the car running back in August. The timing belt had slipped a few cogs. New belt and timed, it started right up and has ran good ever since.
fseriesnut
06-01-2014 08:43 AM
2006lariat
01-30-2014 06:22 PM
dino360
12-29-2013 06:57 PM
RMD69
02-08-2004 08:09 AM
460429_freak
07-09-2003 07:20 PM
Quick Reply: 91 2.3 spark, no fuel,
