Code 1506 AIC control
Old Jul 24, 2007 | 12:10 PM
98range's Avatar
98range
Got a code 1506 for the AIC valve. Truck runs rough at idle and dies at times at stop signs. Cleaned valve with no change.
Question: Do I need to buy new ford part............or is one from Napa, Advanced, Autozone, Checker good enough?
Thanks..........Tom
Old Jul 24, 2007 | 12:29 PM
customstringer's Avatar
customstringer
Don't know what engine you have but NAPA and autozone should both have aic valves for Ranger trucks. I don't know why you'd have to go to the stealership. Check www.napaonline.com or www.partsamerica.com [autozone's online parts catalog].
Old Jul 24, 2007 | 12:32 PM
98range's Avatar
98range
It is a 2.5L
Old Jul 24, 2007 | 12:41 PM
customstringer
These may help:
http://www.napaonline.com/masterpage...+Control+Valve
http://www.partsamerica.com/ProductL...e+Control+Unit
Old Jul 24, 2007 | 08:58 PM
98range's Avatar
98range
Bought one from Advanced for $45.00. At first no change, but after warmed I unplugged the MAF sensor and if idled quiet for 5 seconds then it died. I plugged the MAF in and drove home with out any stalling after that. So that fixed the engine stalling at a full stop. Finally something going right!
Old Jul 25, 2007 | 05:35 AM
customstringer
Always nice to see a problem get solved. If you haven't done it recently I'd consider throwing in a new air filter.
