Im fairly new to the site and to the newer trucks, Ive been researching the fourms on V10's but im not sure if the info im reading is a pick up or not. Im buying a 2003 F350 V10 Dump Truck with 28k. Im not sure what the terminology is on the site for that. But id like to do some reasearch, can some one point me in the right direction and possibly give some feed back, it has 28k miles and its standard. Im buying if for $17,000
You can get more info on the V10 down in the V10 forum.
Your F-350 Dump is basically a Reg F-350 SD with a bed delete option or chassis cab with an aftermarket dump put on. So its basically the same as any other F-350 SD pick-up with a V10.
