Sponsored by: Real Truck
460 Super Duty
Old Jul 19, 2007 | 12:07 PM
maddog440's Avatar
maddog440
Did they have a design change in 2004?
The F-150 went to the 3V engine design in '04. I don't believe the SD got it until '05 w/the new front end treatment.
Old Jul 19, 2007 | 12:14 PM
5.4L to Freedom's Avatar
5.4L to Freedom
Yeah, my 04 is a 2 valve, so I concur
Old Jul 19, 2007 | 03:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
I know that, was just wondering if the 2004 2V head was different.
Old Jul 19, 2007 | 06:07 PM
suzuki0702's Avatar
suzuki0702
yeah the 04 2v has 8 spark plug threads. i havent had the plugs out yet to confirm this information as i have only 40000 miles on my clock. but i havent heard of any 04 sd's spitting!
Old Jul 19, 2007 | 07:36 PM
redford's Avatar
redford
That's kind of what I suspected - thanks.
Old Jul 19, 2007 | 08:59 PM
5.4L to Freedom
How many threads does a pre-04 have?
Old Jul 19, 2007 | 09:04 PM
maddog440's Avatar
maddog440
maybe 4
Old Jul 19, 2007 | 09:09 PM
5.4L to Freedom
maybe 4
You can't be serious?
Old Jul 19, 2007 | 09:39 PM
edgl's Avatar
edgl
I will say it again, the 460 is one great motor, and it pulls hard. I like it over the V10.
Old Jul 20, 2007 | 12:28 AM
DM-03_6.0's Avatar
DM-03_6.0
no problems here with the 5.4. i think a 540 stroker conversion would be mean in an SD i say go for it!
Old Jul 20, 2007 | 12:52 AM
bigjake0524's Avatar
bigjake0524
Have pulled with both motors, the 460 out worked the v10. Would choose a 460 any day as far as fuel wow one gets 9 the other gets 10... The E40 is basically the same thing as the 4r100 talk to a trans guy. Not biased just what I have experienced...
Old Jul 20, 2007 | 12:16 PM
maddog440's Avatar
maddog440
Sadly I am. I can't remember the actual thread engagement length off the top of my head, but it is somewhere in the 5mm range. With a 14mm threaded fastener, they should have about 12mm of thread engagement.
Old Jul 20, 2007 | 12:28 PM
  #28
5.4L to Freedom
Jesus, are my buddies down in dearborn really that retarded? i mean, cast iron is one thing, but aluminum? I hope I hope my '04 has more than 5mm of engagement!
Old Jul 20, 2007 | 04:30 PM
  #29
JKBrad's Avatar
JKBrad
If you have a mid '01 and 5.4 up you should have "PI" heads with 8 threads. Do a search for "PI" heads.
As for the 460 swap. I'd like to see it done by someone who can do it right. You'll need to get the PCM and as many wiring harnesses as possible from a donor truck. You'll need to fab an air intake and mount for the MAF. You'll need to find upper and lower radiator hoses, fabricate a fan shroud, motor mounts and exhaust. It shouldn't be too complicated.
Even though I'm a V10 guy, I've had a 460 and liked it. This swap, in my opinion, is very do-able and should work out well.
Old Jul 20, 2007 | 08:44 PM
  #30
redford's Avatar
redford
Instead of a 460, youd probably have an easier time taking your 5.4L and putting a stroker kit in it. You can easily increase it to a 6.0L torque monster and not have to worry about makng a 460 fit and work with the truck's computer.
