Please Help-Trailer wiring issues/ question
Old Jul 17, 2007 | 10:12 PM
gunpilot33's Avatar
gunpilot33
Question Please Help-Trailer wiring issues/ question
Have a 2004 4x4 F-150 SuperCab.
I have replaced all of the 4 pin wiring to my boat trailer to include the grounds at the lights and at the wiring connection at the hitch. The turn signals and running lights operate normally until I hit the brake pedal at which time ALL LIGHTS go OFF! Is there a fuse that would cause this issue? I felt sure that it was a grounding issue but new ground wires havent helped. Thanks in advance.
Old Jul 18, 2007 | 05:53 PM
rclarke's Avatar
rclarke
That is a classic symptom of a bad ground. Do you have a proper ground wire in your plug-in? You cannot get a good ground through the ball.
Old Jul 19, 2007 | 07:54 PM
gunpilot33's Avatar
gunpilot33
Wiring Issue
Thanks, I will continue to chase the ground wires.
Old Jul 21, 2007 | 03:29 PM
F350-6's Avatar
F350-6
Make sure you check the ground on your truck. The trailer has to be grounded to the truck.
