Ive tried everything to get my truck runnin smooth and nothing has worked and now im wondering if mabie its just the timing being off. I have a 96 f150 4.9L I-6 and i would just go out and time it myself but im not sure if that is controlled by the computer or if i can even adjust it at all.
The truck runs good and preforms well under throttle but if im at a stoplight or whatnot and ideling for a little while it starts ideling rough and I have tried cleaning the fuel injectors with some fuel additive, i have changed the PCV valve and I took apart the throttle body and it looks clean and it still is acting up. So the only thin that i can think of is the timing, also I just wanna check it anaways just because.
Thanks Quick.
It's always my first suspicion ever since I spent almost a year working on my 73 Dodge Charger back in the late 70's for the bad idle. It drove me nuts till a mechanic up the street tipped me off to it, after chasing a similar problem with his aunts dodge for a year. In those days EGR was new fangled technology.
