1965 wiring diagram
#63
I have a set of '66 F-100 / F-250 wiring diagrams. I would be glad to email them to anyone that asks. Drop me a note at "parts@rconnects(dot)com" and put "'66 wiring diagrams" in the subject line.
These are from Ford, however I have found discrepancies between real world trucks and the diagrams. Even so, the diagrams are 99% accurate and can answer most all wiring questions.
Hope this helps.
Hope this helps.
#64
On my 66 there is more than one wire on the hot lug of the Solenoid with the positive battery cable. I believe that is the main power to the fuse block in the cab of the truck.
Can anyone send me this diagram? I swapped a 460 into my 65 and have one heck of a wiring issue. I traced power from the bettery across the front of the truck, into the voltage regulator, into the cab, then into the steering column and that's it. Everything worked when I pulled the truck in to the garage. I'm lost. I have no ignition, headlights, anything. I don't know enough about electrical. It has to be something simple. On the otherside of things the battery goes to the starter solenoid and that's all. No power comes out of any of the terminals. Shouldn't one of these be hot? I mean I can do the old cross the solenoid out and it turns over. I can make the truck run by running a jumper to the distributor. Just cannot figure out why I have no power in the cab anymore. I have redone all my grounds. Even ran extra grounds from the cab to the frame and the front clip to the frame. Sorry to bring up an old post but I have searched and found nothing and I'm ready to just put the things up for sale and take whatever I can get. Please help. Thanks
#65
Charging issues
EricJ. You seem to be a knowledgeable person, yesterday, I installed a new alternator on my 65 f100 352 manual trans. It will not charge unless using a jumper wire. I get battery voltage on the signal wire, and tried 1 electromechanical and 2 electronic regulators, and no luck with any. My plan is to run new wires, and connect to the regulator and see if that works, if that doesn’t work what do you recommend? Also I broke off the rfi eliminator, and I am curious if I can use one marketed for a 65 mustang on cjponyparts?
#66
1965 F100 2WD
I do have the cats meow for 65 truck wiring diagrams...name your series...Ive got em all..from E series all the way to T series...email me with your needs...the book you always see everywhere I have and its sorta kinda close to the actual trucks wiring...but Ive got parts harnesses Ive compared the pamphlet to as well as my book...a FoMoCo published book btw...the Ford book its dead nuts on correct...
- cs65
- cs65
Would you please email me wiring diagram for my 1965 F100 2WD. I need under the hood, in the cab and to back of the truck. My email is. michael@jonesnw.netv,
Oldguyfl
Electrical Systems/Wiring
08-12-2017 10:14 AM
