Getting new HD4R100 today
Well, I roasted one of the clutches in my original transmission this past week coming down Tioga pass and needed a quick replacement. I'm getting the Motorcraft HD4R100 installed today by my local dealer and will post my thoughts and opinions about it for those that may be thinking about getting it as well.
For those that have replaced their transmissions with better units: Will I feel a power difference since it may be a bit more efficient at putting power to the wheels? I know I'll feel more confident in its reliability, thats for sure!
Yes, its a reman unit but with many upgraded parts over a standard reman. Suggested retail price is $3325 and I'm getting it for $2900.
FEATURES / BENEFITS
This exciting new product is built with numerous durability and performance upgrades. These include:
• Enhanced Torque Converter for better performance and longer life
• Oversize one piece case bushing for improved durability
• Enhanced Forward, Direct, and Intermediate Friction plates for longer life under heavy load shifts
• All new special upgraded steel plates.
• Center Support Enhancements for improved gear train life
• Mercon V-OIL for greater heat resistance
• Oversize Pump Gear Set for improved oil flow
• Upgraded Extension Housing Bushing for improved durability
• 45 Element Intermediate Sprag for greater strength to withstand heavy loads
• Special coast clutch drum for improved engine braking and increased durability.
• All new iron planetary assemblies for improved durability
• All new one way clutches for improved durability
• All new electronics for improved reliability
• Revised calibration gives better shifts for heavy duty use
• Improved gasketing for reduced leaks.
FEATURES / BENEFITS
Ford offers the standard reman for about $1000 less that this unit and this unit just became available within the past 6 months or so. The $2900 is for the unit only and labor will add another $400 on top of it.
My part number is a TRM-1622 for a '99 F250. There should be a parts sticker on yours to compare your part number.
I just did the same tranny 3 weeks ago for same price your paying but got a bit of the shaft when it came to the 6.0l trans cooler paid 362 i think. the trans works great the are solid and the only problem is torque converter lockup I dont like it seems to slip more than the stocker but I think its due to programing running sct with innovative tunes.I think you will like the new tranny.
no i think mine is purely due to tranny programing with the sct.Im actually wanting to change that with dp tunes because when talking with innovative he doesnt seem to want to work with me to get this worked out he keeps telling me nothing needs to be changed programming wise even knowing I am no longer runnig the stock tranny.the dealer I bought mine through would give me a warranty without changing th cooler also thats why I went with the 6.0.
Tugly
18
04-10-2013 02:18 PM
bc2sv
03-10-2010 06:58 AM
19992003, 4wd, compare, ford, forum, hd4r100, jody, motorcraft, number, part, powerstrokeorg, price, reman, traderj, transmission
