Lift questions about Add a Leafs & Shackles
I am looking to add a little lift to my F250. I got the Rough Country add a leafs for the front and rear, 2" shackles for the front to level it, Adjustable track bar and Rancho RS7000 shocks all the way around. I realize that some dont like the ride the Add-a-leafs give and Im ok with that. Im hoping the shocks will help a little with that. Is there any other potential problems with this recipe?
Ryan
Ryan
Looks like a good plan to me. I went with the mini-spring pack in front and 4" blocks in the rear. I haven't done the adjustable track bar YET. I don't know where you are getting your parts, but the best deal I found on the adjustable track bar is .
Well I started the install on the rear today. Spent 8 hrs working and only drank 2 beers you know I was hustling. Got all but two of the bushing drilled out and replace. Energy Suspension kit is working great so far. Drilling and beating the seak spring bushings is very time consuming. I have drill the drivers side spring bushings and then install new bushings and reinstall springs. I got both shocks, passenger side springs, and the sway bar bushings all done. So far so good other than I was expecting to do this in 5 hrs or so.
Ryan
Ryan
Finished project? Im not familiar with that term.
I will post pics as soon as I get the front done. I had to get the truck to the bedliner place to get her new sprayed in liner and fix the front window tint. It sits 6 inches higher in the rear than it does in the front. I hope the front springs raise it up as much as the rears did.
Ryan
Ryan
Thats what it said on the receipt and the part numbers matched. I hope it will settle some. As long as the front ones match it I will be content either way. I spoke to Rough Country and they said it should. They were very helpful and easy to talk to.
Ryan
