2003 7.3 oil leak
Originally Posted by uarep
I have a 2003 f-250 7.3 diesel I have a leak at the back of the engine by the torque converter inspection cover, I think it is comming from up top of the engine can anyone give me a place to start or could ot be the turbo cradle seal and how hard is it to fix.
Uarep
Uarep
Doug
I just fixed my leak this afternoon. I read all the posts on these oil leaks and found mine was leaking from the rear plug on the HPOP. In fact it wasn't even tight. I used a regular O-ring(black rubber) and Red loctite. No more leak.
I got a big piece of foam rubber(about 3 ft. square x 4 in. thick. I put it on the right side of the engine compartment so I could get on top of the engine and see down in the valley and clean it up. From a cold start get up on top of the engine, (watch out for the fan and moving parts), Get a bright flashlight and a mirror that will fit down under the HPOP and look under the pump and see exactly where the leak is.Get the o-ring kit or go it on your own like I did. Good luck.Thanks to all those who provided the great information available on this wonderful site.
Originally Posted by af4ms
There are a number of different causes for oil coming through the seep hold in the torque converter cover. One of the most common that I found, and was the cause of mine, is one of the two orange boots underneath the turbo could be either cracked or loose. Each of these boots have two hose clamps on them and mine had one of those loose on the drivers side. Snugged it up and it quit leaking. I was getting around 2-3 drops per trip. Keep in mind though, if it is in the valley it will take 5-7 days of normal use before all of the oil dries up on the back side of the engine. I would clean the valley as well. Others will probably chime in on thoer locations to look.
Doug
Doug
BTW, you're the only other Ham I've seen here.
Joe, N3JI
Originally Posted by Izzy351
If you tighten those and do the CCV mod, you'll get no more oil there. That very thing is what brought me to this site. I saw the oil and did some digging around on the 'net and ended up here. Read the posts about the common causes, did the above, and cleaned the engine with Simple Green. No more oil.
Joe, N3JI
Joe, N3JI
I have a 2M 440 antenna mounted (NMO Mount just above the third brake light compartment) on the roof of my 2000 CC Long Box and the cable fed underneath the liner and have the radio (Yaesu 7100) mounted behind the back seat. The remote head is mounted below the little indention box and works very well. However I dont do well in parking garages.
Good to meet you Joe. This site has provided me with a ton of VERY useful info. Hope to talk to you soon!
73's
Doug - AF4MS
(Now everyone is wondering what is going on. These acronyms are not on the site )
Just about anything and everything you could ever want to do to your truck:
http://www.7point3.com/Mods.aspx
Guzzle's world-class mod & maint write-ups:
http://guzzle.rbmicro.com/
BE WARNED though. Going to these pages has been known to the state of California and the Surgeon General to be leading cause of PMS!!
I havent seen any others myself. I have the CCV mod printed out and am waiting to get caught up on some work to do the mod.
73's
Doug - AF4MS
73's
Doug - AF4MS
Oh yeah, my truck doesn't leak oil anymore, and it runs better than ever since finding this site. That's why I became a supporter. Worth every penny!!
