I have a Ford Expedition '00 and I have problems with the suspension First the check light came on one time and after that the rear is too low before that happened the air compressor it was sound noraml but after the light came on the compressor it was not loud and now is not working at all I need some help with this
Arnott industries out of Florida sells the compressors for around your same price that you pulled off ebay w/ a warranty. I've ordered two for different vehicles and worked out great
Ray
Check the relay under the bumper on Pass side. Search this site for info on LLS and that relay. I and others have posted much on the topic. In my case as someone already suggested it was a bad relay---$100 I think. I've often thought of getting one out of a bone yard and keeping it as a spare.
There is an ongoing debate on this forum as to changing out the LLS for a std spring suspension. My take is, if you haul variable loads and or tow---it's great and worth the struggle to keep it operating. Sure rides nice under all conditions. If you don't need all that--then it's probably cheaper to convert in the long run if you are going to keep the truck.
In your case it's most likely a bad relay or compressor---a little diagnostic time will tell you which.
John I replaced mine on my 2000 this last spring---with about 80K on the clock---well worth the money and time---I did it to coincide with new tires---hopefully the tires will last longer with new shocks---that's been my experience in the past. In any case the improved ride and stability was very noticeable. The truck had started to get a little unstable cornering and towing.
I expected the shocks on this truck to last longer than I would on a car---but I guess I was wrong. So I'm glad I did it at 80K---that will get me to 150K or so and at that point I'll have to decide to keep her going or move on to a new ride.
