Timing connector
Old Jul 7, 2007 | 09:47 AM
djmac's Avatar
djmac
Timing connector
I use to have a Duraspark ignition prior to installing the MSD 6 series module. I have disconnected the vacumn advance to the dizzy because the Fuel injection system controls my timing. But I still have to establish base timing so my question is do I have anything to disconnect to establish base timing with such a system? Just hook up the timing light to #1 cylinder and go?
Old Jul 7, 2007 | 10:09 AM
darrin1999's Avatar
darrin1999
if it were an all stock efi there would be a small grey block youd have to pull out called a spout connector- that part takes the computer out of the loop. with an aftermarket efi system that would use a stock duraspark distributor with vacuum advance disconnected i would have no idea how it could adjust the timing unless you took off the vacuum advance and put an electronic modulator there, otherwise it would just adjust injector timing. i would say you should call the manufacturer of the aftermarket efi and ask them what to do.
Old Jul 8, 2007 | 01:25 AM
djmac's Avatar
djmac
I Checked with the MFG and it a GM based system with the typical GM disconnect. Thanks for your input
