2008 King Ranch 350 Hit While at Dealer
My girlfriend just bought a 2008 King Ranch One Ton Crew Cab (drop dead gorgeous) and had it home less than a week. She took it out for a drive and it died so she had it towed to the dealer. At the dealer's it started right up the next morning so a service person took it out for a test drive and it died on the highway. While waiting for the tow truck to get there a 19 year old in a Pathfinder hit the corner of the truck, crunched the side and broke the light. My friend is of course beside herself. Waited all this time to buy the truck of her dreams and this happened.
What do you folks think are her options? Should the dealer order her a new truck? Could the frame be damaged? Right now she is so furious she wants a new truck and a new option for the time she's waiting, making payments (wow, almost the $ of a new home for some) and not having use of the truck.
Her heart is just broken.
What do you think? Ever had anything like this happen?
Also, do you know why this truck has been dying on her? I wondered if it could be something as simple as the fuel or ...???
KCF
KCF
She won't get a new truck, her truck will be repaired. She should call her insurance agent. Her insurance will work woth the dealership's insurance to get the repairs paid for.
The frame probably isn't bent, based on your description of the damage.
What engine does she have in this F-350?
I concur with redford. A new truck is definately not an option. It is unfortunate but these things do happen. Sucks though, I know I would want a new truck as well but you have to be realistic. On the bright side, being that the truck is new, the paint should be easier to match up as it probably has not started to fade yet. Hope it all works out well for her.
I think the girl should get a new truck, not because someone hit it while it was in possession by ford. She should get a new truck because the new truck she purchased has already died twice, new with problems usually results in more later on. She spent around $50K for that truck, she should get one that works 100% of the time.
It was a diesel
Hi,
I don't know much about the Fords other than her new 08 truck is a diesel and the interior and front is to die for. (I drive a 1 ton crew, duelle, Duramax--sorry guys and gals but they are all outstanding trucks. I pull a 34', 12,000+ horse trailer and any one of the three would pull the wheels off the horse trailers. In reading some of the posts, I can see where if you try out a truck and know you're gonna love it but the one you try doesn't seem quite right, move on to the next one. I tried out 3 Duramax trucks before buying this one. It's an 03 and I love this truck. Wouldn't have given you a plug nickle for the two prior ones I tried.)
I, too, wondered why her new Ford has died twice. Thought it might be the fuel but she said she's only used one-half tank fuel since she bought the truck.
By the way, this is a warning--be careful at those BP stations. The green handle pumps have this little tiny oval that says "gas" on them. I filled my Duramax full of gas! Had to have it towed across the street and drained. BP would do nothing about it. Said this was a high level corporate decision to have green handles for gas and black for diesel. The station said at least one truck per week fills with gas instead of diesel.
Happy trails to you.
KCF
KCF
well, technically, it only failed once. the second time, it was on a test drive so the mechanic could duplicate the condition. so, really, its only once. the lemon law, which is different from state to state, usually means it has to have the failure 3 seperate times and the dealer must make an attempt each time. this is only the first time.
WELCOME to FTE!
Unless the dealer roles over (not going to happen), her insurance and the dealer's insurance will cover the repair.
If it was a blatant liability thing, like the mechanic hit someone else, I could see the dealer going out of their way to do something - maybe.
But in a case like this, the most they would (or should) do is give her a loaner until it's fixed. I've read almost the exact same thing happen over and over again, and all it comes down to is - it gets fixed. And most of the time, looks as good or better than it did brand-new. The one thing I'd try to get is a 3-year warranty on the work, if possible, or even longer.
I was sick to my stomach the first time I scratched the paint on my '01 on the rear door, just under the molding, down to the metal.
I got it painted, it was only painted below the moulding, and you can't even tell. Matter of fact, the new paint is better looking than the surrounding area, and 3 years later, it's not even possible to tell. And that's a clearcoat.
As to why it's dieing, visit the 2008 6.4L forum, and ask there. Lots of helpful people in there...
here's the issue with them just repairing it. the paint will be far sub par in quality. will most likely scratch very easily as the depth of the clear coat will be a lot thinner. the 19yo's insurance should also cut her a check for the lost value in the truck now that it has been involved in an accident. if she's really wanting a new truck, she's gunna have to go after the 19yo's insurance company.
Originally Posted by KCF
On the lemon law, is there a time limit, i.e., three times within the first year?
Thanks.
KCF
Thanks.
KCF
KCF you need to get your girlfriend to fight to get a new one now. She shouldn't have to take a $50K truck with problems from the get go. She should contact her salesmen and the sales department manager and tell them it is unacceptable. It is a safety issue if it dies on the highway, especially if you are pulling a trailer.
https://www.ford-trucks.com/guidelines.html - see Section 8.
thanks.
Utto. Sorry. What did I post wrong? The green pump handle or lemon law? I really didn't mean it to be a slam on the station, just to warn folks not to use the green handle. Use the black one. Cost me almost $400.00 because I didn't take the time to read the little oval warning. Again, sorry.
KCF
KCF
