Body lift
#1 Take the bed loose and move it back or else you will have a big gash right behind the cab where the bed wraps around the cab.
#2 Fan shroud is a pain in the a$$ to get right.
#3 I highly reccomend the performance accessory body kit it comes with EVERYTHING!!
#4 Take your time and do it right and hook everything up that is supposed to be hooked back up and you will be fine. I did mine in my drive way with a 2 ton jack and it was very simple. The trick is take the bolts on one side loose very loose but not all the way out and then pull the ones on the other side all the way out lift up that side and put your spacers in and hand tighten the bolts then put the spacers in on the other side. There is before and after pics in my gallery link in Signature.
If you have anymore questions just ask.
<!-- BEGIN PRODUCT DETAIL CONTAINER TABLE WITH HEADINGS --> <table border="0" cellpadding="0" cellspacing="0" width="555"><tbody><tr> <td colspan="2" height="19" valign="top">
</td> </tr> <tr> <td colspan="2" height="6">
</td> <td width="10"> </td> <td bgcolor="#8c8c8c" width="1">
</td> </tr> <tr> <td colspan="2">
</td> </tr> <tr> <td colspan="2"></td> <td width="10"> </td> <td align="right" valign="top" width="80"> $29.99</td> </tr> </tbody></table> </td></tr><tr> <td colspan="2" height="10">
