Why the need to switch to a 10w30? Do you have oil pressure problems? If not the factory 5w20 will work fine.
I have no problems but im just curious. Because I dont need the 5W protection in FL anyways. The coldest it ever gets in winter is like 40*F and summers are in the 90's.
The 5W insures that oil gets up to the cams as fast as possible on start-up to eliminate wear. The cams ride directly on the aluminum heads with no bearing in between. The 5w20 is also easier to pump so you gain a little hp as well.
