drain plug stuck!!help!!!
hello, i went to change the oil in my manual transmission and the hole where you put in the 3/8 drive stripped out on the first turn like butter!so i get out the easy out and it breaks off in the hole and now i cant get a drill to go through as the easy out is a more tempered steel.any ideas???is this plug a right hand thread or what???
Then someone's been in your porridge. The fact that it's a manual was noted from post #1; this means it's a ZF5. As said, the fill and drain plugs on a stock ZF5 are both 22mm. No doubt some metric thread (it is a German-designed tranny, after all). A plug with a 3/8 square drive is usually NPT thread. Someone must have been monkeying with your tranny to have changed it. Maybe some kind of insert. Your remedy might just be to remove that insert (presuming that's what was done).
See that wide flat area around the fill plug? The original plugs have a wide flange that covers that area. I didn't pull either plug to see if it had a flat gasket like an oil pan drain plug gasket to cover that space. In any event, that's evidence that those are not the original plugs. Dunno where you'd find 'em, though. Nothing at RockAuto. A general Internet search just comes up with a bunch of forum threads.
Update - I see part explosions / manual pics of both:
http://www.zf.com/media/media/docume...ce_manual_.pdf - page 28 - shows the wide flange hex plug. (Interesting, this PDF is on ZF's site, but it's a sloppy scan from a Ford manual.)
http://www.manualtransmissionpart.com/ZF-S5-42.html (click on the thumbnail of the diagram) - shows a square drive headless plug. This site at least has a part number (either 359483B or 359483A), but no price, so presumably not available.
BII Plow Truck
2017+ Super Duty
10-26-2017 07:14 PM
Missin'A Gear
08-30-2014 10:23 PM
