A REAL cold air box...and CHEAP!
#33
OK... So I do have to rain on the parade of praises here and ask a question...
Don't our cooling fans blow out toward the radiator? If so, then wouldn't all that warm air be blown thru the radiator and be let in thru the air box inlet? Just curiuos... I could be totally off base... That's kind of why I like the 4.9L air box, it actually hooks to the side in order to pull air from behind the headlight and not from in front of the radiator...
#35
I've been reading up on the WAI (Warm Air Intake), and it seems the whole fuel atomization occurs, when the air is WARM.....Seems the colder air/fuel mixture tends to stick to the sides of the intake manifold....
Whereas the warmer air (Which we all know warmer air expands) spreads the air/fuel molecules around, thus giving a more evenly mixed A/F mixture....
Fords on the other hand (being technically superior ) do not suffer from this problem. The multiport fuel injection system injects the fuel much later in the game (right before the air enters the cylinder), and atomizes it much better. A warm intake charge will net you almost no gains because the fuel is already atomized very very well with this setup.
Hope this helps
#36
Air is pulled through in the same direction that it flows naturally when you are driving on the highway.
#37
#38
Received 5,139 Likes
on
#40
on
#42
#43
on
#44
Yeah, it is really sweet. Not mine though. I did a google search for a hood like that, and that was those were the best pics I could find. If you want to see more of this truck, here is the website I pulled the pics from: October 2009 Gen 1 Truck Of The Month–Congrats Billy "lightning_2000" Dunn(NLOC#2643) - The National Lightning Owners Club Inc
