"I know I am tdc cause I had my wife bump it over". What does this mean?? This is very ambiguous.
Each piston has TWO TDC's in its cycle.
One at the end of exhaust stroke and one just before Power stroke
as mentioned earlier.
You need the 2nd one.
Also there are different timing settings per whatever engine you actually have
which is why I usually instruct people to go to the 385 enigne forum where ALL the 460's are discussed.
Just wanted to say thanks to the guys that helped me out. I went and got a new timing chain and gear set and balancer put everything back together and it is runing fine. Other than the starter went out on me today(I can handle this on my own).
