Remanufactured Turbo Warranty Replacement
03 F350,15K miles, purchased new, only driven when pulling, recently had CAC hose tear at the turbo charger, took to dealer and boost was out of spec. Service writer stated that if any corrosion found in turbo that it warrants a replacement. The dealership installed a reman turbo.
The turbo hose had previously been disconnected several times under warranty. Engine removal and reseal, 2 turbo pedastal replacements, and turbo Y pipe replacement also in an effort to get rid of my 1200-1500 rpm engine vibration. I think it was worn out from R&R.
Service writer told me that Ford had started using differrent metal compound to prevent corrosion but could not tell me what was different as it is proprietary information.
My questions are:
Did Ford improve the replacement remanufactured turbos?
Is a warranty replacement usually a rebuilt part?
The new turbo has turbo lag from dead stop where my other did not from new. Any suggestions?
Thanks
My questions are:
Thanks
yes they re-designed the turbo in 04 and i believe the 03 turbo has less vanes and spooled a little quicker...also sounds awesome with exhaust on it...but new/reman turbo as much as you let it sit your gonna get lot rot again and continue to have more problems....the 03-07 6.0 with the VGT turbo was not meant to sit the only thing you could do is drive it atleast a couple times a week get a aftermarket turbo or trade it for a 08............
P.S welcome to the forum!!! theres alot of good info here.
surely they should have fixed/eliminated the problem by now(on the 6.4's).....after all the turbos they replaced on the 6.0's plus with his 5/100k running out soon its all gonna be out of his pocket so the new truck will give him a fresh warrenty...
I just had a remanufactured turbo installed last week on my 03 also. My last remanufactured turbo lasted exactly one year and 18 days. If it failed 18 days earlier I wouldn't have had to pay the deductible again. The dealer said it had rusted vanes so it could not be cleaned. I am surprised because though I only drive the truck about twice a week, I make sure to hit full boost (25-28 lbs) a couple of times when I do drive it. I use Diesel Kleen, I change the oil frequently, I don't idle it excessively.. I'm very surprised by this one. Even so, I still love my truck.
Originally Posted by darsey715
that is a shady dealer. Im sure they meant the exhaust side of the turbo itself rusted but still I doubt it was THAT bad they couldn't clean it and HAD to charge you $100 again. I mean, it was only a year. I suggest trying a different dealer or if it happens again specifically ask they clean it if they are gonna try and charge you $100 bucks for an ongoing problem. I don't think the vanes themselves can rust.
Originally Posted by oldwo
Did Ford change something in the turbos to prevent the rust/corrosion issue?
Originally Posted by vloney
Not so much on the 6.0, they pretty much are the same. The vanes dont rust, the unison ring controlling the vanes do. The 6.4 turbo, while having one "side" vgt, uses an electronic actuator instead of the oil operated vgt solenoid. Whenever you first turn on the key, the actuator cycles the full travel to keep everything free. This doesn't mean it can't happen, but it is less likely. The vgt turbo also is redesigned from the unison ring days.
Is there anything at all that can be done to prevent the rusting? I'm considering putting a rubber cap over the tailpipe in the winter when the truck is parked for several days at a time. Does that sound like a waste of time or am I on to something?
One product of combustion is moisture. Its this source that causes the rust and corrosion. If you park it when its hot, there should be enough heat to evaporate all the moisture. Short trips, where everything doesn't have the chance to get hot, is what hurts.
Thanks for the reply. I actually had to do more short trips than I wanted to last winter. I guess I will just have to do something about that, which in a small town where nothing is over two miles away, can sometimes be hard to avoid. Maybe I should high idle it for longer before I go out?
