Camper roof seams
Camper roof seams
Hello all,
I have a 1993 Holiday Rambler 29' camper. I just towed it home after it was sitting for 5 years or so on our camp.
I washed it, and can actually see the roof now. It helps that I parked it next to my deck, which is 10' high.
After washing it and inspecting the roof, it looks like the roof is fiberglass with seams covered in silver tape (almost like duct tape).
A couple of the corners look like they have cracks in the sealer. How do I fix it and what do I use? Is there something special, or should I just use some good silicon cauking?
Same goes for the areas around the vents. It looks like there was some gunk spread around the edges and I'd like to touch it up.
Thanks!
Thanks!
Stay away from silicone. A self leveling urethane sealant might work or there are several repair tapes on the market that you could use. Before applying any sealant be sure to wipe down the area to be repaired with something like acetone. That will help in making sure your roof is clean. Even great products don't stick well to dirt. If you go with a repair tape you could get a cheap version at home depot or look online for a better product. I've used Eternabond (www.eternabond.com) on several things and it's stuck to everything except teflon really well.
I wouldn't use self leveling sealer for a rubber roof on fiberglass. There is some stuff we use called C-10 Flow seal which is essentially the same thing but I usually only use it on aluminum roofs. Professionally I use a sealer called Dyco 20/20 brush on for the fiberglass. It's a good flexible sealer you can put on really heavy and the thing I like best is there is little prep work involved just knock off the loose stuff.
You can't use it on rubber though it will eat right through it
DICOR
-Lap joint sealant. Self levelling, and made for that. It comes in caulk gun tubes, so you need to dump a whole whopping $2.99 for a caulk gun to apply it.
Ummmm.....
I have completely lost count now, someone help me here. How many times have I said GET UP ON YOUR ROOF AND LOOK AT IT????????????????
I wasn't kidding.
Please surf these links: LINKS TO INFO
Ummmm.....
I'm afraid to get up on the roof. I am big.
But I got up on a ladder to clean the roof and got a great view.
How much do roofs hold, anyways?
Thanks for the info, I saw the eternalbond tape and it looked pretty slick. I think that must be what is on the fiberglass roof seams now. I'll check out the dicor.
It looks like there are some cracks at the 4 corners of the seams on the roof.
I would use what came on it originally which sounds like Eternabond tape. It is made for your application as well as sealing trailers on 18 wheelers.
http://www.eternabond.com/
Gene
Gene
You can order the Eternabond tape directly from the company. I had an email exchange with them a few years ago and if I recall correctly the man's name was Christian that I dealt with.
My memory is that it comes in two colors, white and chrome-like aluminum.
You mentioned that your tape looked like duct tape. I'm not sure if you are referring to the commonly available duct tape or the type that is a very shinny, peel and stick product that is used in the heat and air conditioning industry. The Eternabond is more like the second type but the aluminum backing of the tape is thicker and the glue is more tenacious. A bondo spreader is a good tool to use to press the tape down with.
As Poohbear said, you can get on the roof of most RVs. If there is any evidence of where the supports are like screw or rivet lines try to stand on them. If you are just doing the perimeter roof seems you should be able to work from a ladder.
Gene
Gene
The more I look at it and read up on the internet the more I think it is the silver eternabond. It runs over the main seams on the roof, right down the middle over the rivits and accross both ends.
At the four corners is some other gunk, which is cracked a bit. Same gunk around the skylights and vents.
Dicor lap sealant works on fiberglass . This is what they use around vents,skylights any opening in the roof.
northwindone
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
03-25-2015 09:04 AM
meborder
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
10-25-2014 07:56 AM
djanzen
09-24-2011 07:34 AM
