SBF Edelbrock Heads
SBF Edelbrock Heads
i have a pair of fully assembled from the factory brand new Edelbrock RPM heads for a SBF that i can't use and need to get rid of.
i had them on my truck for a day and nothing ran right and it turns out that my block is decked too low and every intake valve on every cylinder was hitting the piston.
so here's the skinny:
-im willing to let BOTH of them go for $750 + s/h !OBO!
-nothing is wrong with the heads, just need new intake valves.
-these heads retail $560 a piece brand new from jegs.
here are the jegs details...
Ford 289-351W Performer RPM Aluminum Cylinder Head
170cc Intake Ports
60cc Combustion Chambers
1.900'' Int/1.600 Exh Valves
1.460'' Valve Springs, .575'' Max Lift
Assembled, Sold Individually
350-60229
Designed for non-emissions 289, 302, and 351-Windsor Ford engines, these direct bolt-on heads deliver maximum performance in the 1500-6500 rpm range for all high performance street applications and our Performer RPM Power Package. Performer RPM head #350-6022 has 1.90'' intake valves for use with stock pistons; #350-6025 has high-flow 2.02'' intake valves which require aftermarket pistons notched for valve clearance. Will not accept rail rockers.
170cc Intake Ports
350-60229
1976f150dude
21
03-27-2024 09:15 PM
the lotty
03-29-2004 08:48 PM
