Benefits to removing red line from wastegate?
Old 06-15-2007, 09:34 AM
viperbluelx's Avatar
viperbluelx
viperbluelx is offline
I'm trying to figure out if I'm supposed to have the red line off the wastegate after installing my Xcal2 programmer? I removed it and the SES light came on with the first WOT run(due to overboost I'm sure) and so I stopped and plugged the line back onto the wastegate and the SES light hasn't been back on since and the truck feels just as strong as with it unhooked.
Old 06-15-2007, 09:42 AM
Texas Outlaw's Avatar
Texas Outlaw
Texas Outlaw is offline
Not a liberal...
When I unhook mine I get extreme turbo surge and the truck runs like crap. I hooked it back up and have left it alone ever since.
Old 06-15-2007, 09:46 AM
viperbluelx
Have you had any overboost codes with it hooked up or do you already have some sort of boost fooler in place?
Old 06-15-2007, 09:51 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
if you was in it hard.. you could have set the SES light off by asking for more fuel then the HPOP could give it..if the turbo boost is too high it will defuel the truck...
Old 06-15-2007, 09:55 AM
viperbluelx
Yeah there are no codes stored in the computer, but the SES light came on after a WOT hit and then went off about a mile later and hasn't been back on since I hooked the wastegate line back up.
Old 06-15-2007, 09:57 AM
fbilly420's Avatar
fbilly420
fbilly420 is offline
i have the ts performance chip and with my waste gate connected i could get over boost codes even in the 75 setting. I just installed my home made boost fooler and i can run wot with no ses. It is very exciting to run like that without defueling. I didnt think my truck could do that i had a grin on my face for a couple hours.
Old 06-15-2007, 11:57 AM
Texas Outlaw
Not a liberal...
I have never thrown a code, ever. I don't have the boost fooler but do have an overboost relief. I am thinking of switching that out to the Annihilator though.
Old 06-15-2007, 12:46 PM
15 and 92 Dad's Avatar
15 and 92 Dad
15 and 92 Dad is offline
When I originally bought my super chip they sent me a piece of tubing with a small hole in it and said to intstall in line with the waste gate line? I did, I guess it works, If i remove the redline I get the SSES light at WOT!
Rich
Old 06-15-2007, 09:02 PM
MTDewX's Avatar
MTDewX
MTDewX is offline
I have mine removed, (friend just did it) and I dont get any SES light. not sure if it does any good or not. so I just left it. I have a Diablo programer on the 65 tune.
I do get the 470 code. maybe that has some thing to do with it. dun't know really
Old 06-16-2007, 07:23 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I have the ITP OBA and I yanked my wastegate line to see what the difference was. Seems like the turbo really likes to get up above 20psi pretty quickly now. The only codes I get are when I'm really into it and the HPOP can't keep up...
Joe
Old 06-16-2007, 07:38 AM
Uzumati's Avatar
Uzumati
Uzumati is offline
The reason for the red line.
A wastegated turbo is designed to reach maximum boost sooner then a conventional turbo, but overboosting will cause damage to the turbo. The PCM will control the boost pressure by duty cycle to the solenoid to maximize boosting performance (no more than 16-1/2 psi). When pressure is supplied on the red hose going to the actuator (solenoid NOT energized) the valve will open, dumping boost. When low or no pressure is on the red hose going to the actuator (solenoid is being energized), the valve will stay closed.
Old 06-16-2007, 08:14 AM
viperbluelx
so i'm limited to 16.5 lbs with the line on?
Old 06-16-2007, 08:22 AM
Uzumati's Avatar
Uzumati
Uzumati is offline
In completely stock form that is what the PCM tries to control it to, but the turbo is capable of well over that, although 25psi is about the limit of its efficientcy.
Old 06-16-2007, 12:20 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
The 470 code is for the EBP sensor, you might want to clean the tube from the exhaust manifold to the sensor it's probably getting clogged with soot.
Old 06-16-2007, 08:18 PM
mattpowerstroker's Avatar
mattpowerstroker
mattpowerstroker is offline
amiller are u saying the turbo is only good up too 25 or will a stock turbo hold more
Quick Reply: Benefits to removing red line from wastegate?
