hutch finally done now no start!
So hutch mod is finally done, and with all the problems I had it took me about 10hrs (wife is mad and kids hell even the dog) So when I was done I had no leaks . I cycled the fuel pump 6 times for 30 each time, she fired right up, I let her warm up and went for a test ride. That little voice inside my head said no to go far so I kinda listened. So long story long she bucked and died, and now she wont start at all. So after jogging the 1.5miles home I got the wife to tow me with her suburban (she was thrilled to be doing this at midnight) so what gives!
here are the facts
6 CYCLES 30SEC EACH ON FUEL PUMP
HAS ABOUT 3-4 GAL IN THE TANK
BUCKS LIKE CRAZY
I CAN HEAR THE FUEL PUMP RUNNING
NO LEAKS ANYWHERE
OH YEAH WHEN TOWED HOME RIGHT WHEN I GOT HOME I HAD TRANNY FLUID EVERYWHERE. AFTER CHECKING THERE WERE NO LEAKS IT WAS COMING FROM THE FILLER TUBE, WTF? IT WAS TOWED IN NEUTRAL WITH THE KEY OFF WHY WOULD THE TRANNY FLUID SPIT UP?
THANKS FOR ANY ANSWERS
here are the facts
BUCKS LIKE CRAZY
NO LEAKS ANYWHERE
Go Get More Fuel, in 5 gal cans if you have to, lets make sure that it is not a low fuel starvation problem. 3-4 gals barely wets the bottom of the tank and when you are driving it is sloshing around wich could pull air in the pump.
Just my .02
adjusted for todays inflation which means its worth nothing.
Just my .02
for the hutch mod, make sure you have some diesel in the tank. the main problem is, as pumps get weaker, its harder for them to pull the fuel through the filter. You were probably just running on fuel left in the bowl and lines.
Things to check-
Take the stock filter cap off and turn the key on. Make sure there is fuel getting up there. Probably not, so put some more diesel in the tank and take the air hose and blow some air in the main take while the fuel pump is running. This will help prime it.
I check this before I even tried to start mine after doing the hutch. The pump wasnt priming and I didnt start it until I got it to. If you would have filled your tank right away, you probably would have been ok.
Things to check-
markjones333
01-12-2015 11:42 AM
markjones333
01-11-2015 09:32 PM
fmr9
40
11-01-2007 11:35 AM
