Coolant temp sensor
Old Jun 10, 2007 | 07:01 AM
vaman4215's Avatar
vaman4215
Coolant temp sensor
Where is the coolant temp sensor located at on the 7.3L engine??? My temp gauge doesn't go all the way to cold, but stays on low end of normal, need to see if it's the sending unit or the gauge...
Old Jun 10, 2007 | 07:14 AM
PLC7.3's Avatar
PLC7.3
On the block just ahead of the left head upper corner...... there is a wire loom with 2 wires exiting one is the temp sensor (straight connector) the other is the overheat switch (90* connector) front lower corner of the head. Worst part is it's all located behind the A/C compressor adapter plate.
Old Jun 10, 2007 | 10:41 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Front of the drivers side head, under the AC compressor.
Old Jun 10, 2007 | 10:45 AM
PLC7.3's Avatar
PLC7.3
Dave update the pic with the serial number location....flat area on the top of the block.
Old Dec 27, 2009 | 08:36 PM
mechelement's Avatar
mechelement
What did you use to thread those in there? Plumbers tape? The wire going into the boot of my temp light switch is exposed. Can you get those boots at a parts store? I took that temp light switch off tonight and had coolant pouring out. Do I have to burp the system because of that? Will fluid come flying out the temp gauge sending unit? Right now I have the wrong sending unit the parts store gave me.
Old Dec 27, 2009 | 09:43 PM
Dave Sponaugle
I used Teflon plumbers paste when I installed them.
Yes both are screwed into the cooling jacket, so you will need to drain several gallons out of the cooling system or take a bath in antifreeze.
Buddytr
Feb 3, 2016 08:40 PM
bh70116
1978 - 1996 Big Bronco
Aug 29, 2010 06:32 PM
carrfamilynj
Sep 23, 2006 09:54 AM
cpofaulk
Electrical Systems/Wiring
Jul 14, 2004 07:32 AM
Smokey0210
Oct 13, 2003 07:31 AM
