08 F250 keyless entry pad?
So last night after the Dodger game some budies were tryin to figure out the combo to the truck, and it locked up. Does anyone know how to re-set the key pad. For what ever reason it wont take my code and when I called ford all they could do was tell me to bring it in.
Nick
Nick
on
Keypad Code
The original "burned in" factory code should ALWAYS WORK. It is possible that they erased a secondary code that you set. If the original factory code will not work, try disconnecting the battery or batteries for a minute or so, and then try the original factory code again. The code can be found on a plastic card that was supposed to have been given to you along with the owner's manual.
RON
