I installed the Diablo Delta chip that I purchased from your co.today.To jog your memory it was for a 02,SD with a Banks PP,code EGB3.All seems well and it has added more spunk to my truck.My question is,Does the RPM limiter still exist when the chip is on,and if so,does it kick in at the same rpm's as stock (roughly 5250 rpm)?
