having problems with my holley
Old Jun 7, 2007 | 02:39 PM
marioc956's Avatar
marioc956
Its a 600cfm vac sec .66 jets and .25 squirtter with longtube headers, accel plugs,9mm ford racing wires and a crane cam energizer I cant get it to idle right if I close the idle mix. to 1 1/2 turns I have a problem turning it on I have to give it like 3 turns so that the truck will turn on with no problems but then it smells alot like gas when idle what can I do to fix this
Old Jun 7, 2007 | 08:41 PM
kermmydog's Avatar
kermmydog
Do you have a reverse idle Holley 4160?
Old Jun 8, 2007 | 09:39 AM
marioc956's Avatar
marioc956
whats a reverse idle
Old Jun 8, 2007 | 12:15 PM
LxMan1's Avatar
LxMan1
What is the list number of the carb?
Old Jun 8, 2007 | 03:27 PM
marioc956's Avatar
marioc956
4160 another problem I have is that if im at a light and step on the throttle about midway and let go my truck will turn off only if im in drive wont do it on park
Old Jun 8, 2007 | 10:26 PM
LxMan1's Avatar
LxMan1
The list number is located on the front right side of the choke horn. 4160 is a series number for a square bore vacuum secondary carb.
