Excursion Sway --- F250 Springs???
#31
Originally Posted by S_Harvey
Wait, wait, you mean that B versus C versus D code height info doesn't apply to the 250/350 springs? On all the threads and posts I read (back when I did my research), the info seemed to jibe with that info relating to the 250/350 rear springs, and it proved correct when I did my swap.
Now you have me doubting the info I downloaded into my brain!
Stewart
Stewart
Myself, Bruce and others would love to put a chart together, but load versus deflection charts are harder to put together for the rears. Bruce did create a post on dieselstop for a rear spring data chart, but no one has contributed, myself included. You need a bunch of weight, scale, tape measure and time.
#32
Originally Posted by 6686L
RE REAR SPRINGS:
I do not see the point in monkeying around with spring rates. I like nice soft springs. I control riding height elevation with air bags. Installing a couple of air bags is a HELL of a lot cheaper and a HELL of a lot easier than monkeying with springs, especially since you cant always predict that the result will meet your own personal preferences.
As far as predicting the result, that is what we are all trying to accomplish here. With good folks experimenting and reporting their results, one can make an educated guess on what might work for them.
#33
For those of you who have gone to the 'taller' spring, meaning that your ride is now 1.5" to 3" taller, were you able to use the stock shock or correct shock for the X if going aftermarket (bilstein, rancho, etc...) or does that not even matter.....
#34
[QUOTE=6686L].
RE SWAY BARS:
I am new to Excursions. I bought a creame-puff late '05 production Limited. I can not imagine what Ford was thinking of releasing these from the factory without a rear sway bar. It wandered when it was EMPTY! Scary when loaded. The addition of the Hellwig rear sway bar dampened the "sway" issue down to "barely noticeable".
QUOTE]
NOW I BOUGHT MINE USED, BUT I LOOKED UNDER MINE AND I HAVE A SWAY BAR. IT DOESN'T LOOK AFTERMARKET AT ALL. LOOKS FACTORY. WHEN DOING THE HELLWIG DO YOU REMOVE THE FACTORY ONE, AND REPLACE IT WITH THE HELLWIG, OR DO YOU USE BOTH??? AND ARE YOU GUYS UPGRADING THE FRONT AS WELL? i HAVENT TOWED WITH MINE YET, BUT ON THE ROAD IT DOSNT SWAY THAT MUCH, UNLOADED. I LIVE IN THE HILLS WHICH HAVE VERY CURVY ROADS, THE X HANDLES JUST AS GOOD AS MY OLD KIA SPORTAGE. ONLY DIFFERNCE IS OVERALL SIZE.
IS THERE A LEAF COUNT DIFFERNCE IN THE DIFFERNT CODED SPRINGS LIKE 4 LEAF VS 6 LEAF OR ARE THEY THE SAME COUNT??
THERE IS ALOT OF GOOD INFO IN THIS THREAD FOR SURE. KEEP UP THE GOOD WORK.
RE SWAY BARS:
QUOTE]
#35
I have V codes and unmodified F codes (new from dealer). They raised my 03Ex PSD 4x4 1in. in the rear and 2in. in the front. Front is now 39in to wheel lip, rear is 40in. I got Rancho RS9000X shocks and they sent me the regular ones for an Excusion and they worked fine. In bilstiens most people use F250 shocks up front and standard Ex shocks for the rear. The rear Ex shocks have a different attachment at the top. A bracket with 2 screws instead of an eye with a bolt.
Ben
#36
Originally Posted by Benjoman
Billy
Ben
Ben
Thanks for the info, Ben.
Just to clarify, you have V code in front and F code in rears? And when you stated that most that use Bilsteins go with the F250 front and X rears, did you mean those who also do the springs like you did or just in general regardless if updating the springs (or both)
I have sooo much to learn.......
#37
For Jack - and his question about adding sway bars
You apparently didnt read mine and some of the other "posts" carefully. Let's try it again. We got the Hellwig rear sway bars because SOME Excursions (apparently only the "Limiteds"), came from the factory with NO rear sway bar. Again, I cannot understand what Ford's people were thinking of, releasing a heavy vehicle with "de-rated" meaning SOFTER springs than the normal 1 ton chassis upon which the Excursion is based WITHOUT ANY REAR SWAY BAR. That is why we put on the Hellwig.
To my knowledge, ALL Excursions have a FRONT sway bar.
#38
Originally Posted by TowRig
I hate to be the guy to mess with info in one's head, but that is the case. LOL.
One of the things that makes forums so great is the free info, with everyone helping each other out. But it's a double edged sword because there is so much bad info being posted too.
I hate bad info......with a passion. And to think I was the cause of some bad info being posted here at FTE.....grrrrrrrrrrr.
My V10 came with C's in the front. The diesels came with D's. The fact that you put B code rear springs in the rear and lost 1/4" was a coincidence. I thought most gained a half inch, but I can't say for sure.
This whole time I was under the impression that chart Bruce put together was for fronts and rears.
I'm glad back when I did all my research, I based my decisions on other peoples results with the V's and B's, and only used the chart as a reference tool.
Dude, you've earned some rep points from me for correcting the info I posted. Thank you.
Stewart
#39
The reference to Bilsteins was for shocks after installing F250/350 springs. For the front Bilstein F250 Front 4x4 shocks Part# BE5-2818-HO and for the rear Bilstein Excursion 4x4 Rear Part# BE5-6209-HO were recommended by Bilstein when people called to order.
These are some numbers I wrote down several months ago. I did not get Bilsteins. I got Ranchos because I wanted the adjustable feature. After 6000mi I am happy with them so far.
Ben
#40
Ben
#41
...were recommended by Bilstein when people called to order.
Shane said the fronts can use the extra length the F250 shock gives because the front V code springs raise the Ex about an inch an a half, but the Excursion Bilsteins for the rear are long and have a lot of travel. He said you could put a 3" lift on the Ex and still use the stock Bilstein for the rears.
Front: BE5-2818 (OEM length for the F250 4x4)
Rear: BE5-6209 (OEM length for the Excursion 4x4)
Stewart
#42
#45
Originally Posted by i eat hybrids
If B code doesnt give me the two inchs that i want in the rear, then what springs should i get? Do u guys think i should go with bags?
Ben
Before and After pics of my Ex: http://good-times.webshots.com/album/558111238bzRiOW
