2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Memory seats
Old 08-06-2007, 02:45 PM
CarbonClear's Avatar
CarbonClear
CarbonClear is offline
Memory seats
I'm wondering if anyone has had problems with the memory seats? Mine are not working. The power seats themselves are working, but when you try to save the seat position using the recommended procedure to memorize it doesn't do anything. Has anyone run across this? At first I thought it had something to do with key remotes, but I checked those and came up with the same result.
Does anyone know where I can get a complete part and repair manual for the Expy. I know they were available for my f150.
Any information regarding this would be greatly appreciated
Thanks
Old 08-06-2007, 06:30 PM
berry1234's Avatar
berry1234
berry1234 is offline
The seat won't go into the saved position unless it is in park or the car is off. If it still doesn't work take it back to the dealer.
Old 08-06-2007, 07:30 PM
CarbonClear
Berry thanks, I will try that
Old 08-07-2007, 09:37 AM
Baumbach's Avatar
Baumbach
Baumbach is offline
It may not be the safest thing to do, but to use the saved memory positions you do NOT need to be in park with the engine off, on the 08 limited the seat, side mirrors, and foot pedals will also move even while driving if you shift into to neutral and then select either memory position 1 or 2. Again not recommended but can be done.
You can save the memory position to 1 or 2 at any time, i.e. in gear, moving, engine off/on, etc.
ke6zmy
01-17-2010 07:13 PM
racerock
1997-2006 Expedition & Navigator
07-19-2006 11:58 AM
zel0
04-11-2005 09:10 PM
msparc
10-19-2004 07:26 PM
Quick Reply: Memory seats
