1978 - 1996 Big Bronco
Tow Rig
Old May 31, 2007 | 10:00 AM
Mooseis2402's Avatar
Mooseis2402
Tow Rig
I'm looking for a trailer to haul my 78 Bronco on. The problem is the truck is about 84 inches wide at the wheels (35/12.50's) so getting it on a 6'10" wide trailer may be a little tight....not quite sure if I can squeeze that in there but common sense tells me no. Other than getting a bed over trailer or changing out the tires to get the Bronco on and off the trailer anyone have any suggestions on an appropriate trailer? <!--IBF.ATTACHMENT_56088-->
<!-- THE POST -->
Old May 31, 2007 | 07:12 PM
lostin90s's Avatar
lostin90s
Get a flat tilt back style trailer . The axles low profile wheels are under the flat bed like roll back. This is my next trailer. I get allot of rides that don't run so this will help me load them . Most I see are alum but I bet you can get a steel one. Good luck
On my trailer now I have ramps to go over fenders om trailer to haul my tractor . they come off for normal use.
GOOD LUCK LOST
Old May 31, 2007 | 08:29 PM
79-400-POWER's Avatar
79-400-POWER
when i pulled my bronco home i used a 16x10, and it has 33\12.5's on it.
it was tight but id did fit fine and i would use it again.
Old Jun 1, 2007 | 08:39 AM
3broncocrazy's Avatar
3broncocrazy
I cut the fenders off my trailer and drive mine over the t/tires - no problems......Yet
Old Jun 1, 2007 | 11:20 AM
surewhynot's Avatar
surewhynot
I have a trailer that has fenders that are designed to be driven over.
This site- http://www.rollsrite.com/tagalong.html has one similar to mine to give you an idea of what I mean. Scroll down till you get to # 15KP20DE
Old Jun 4, 2007 | 12:08 PM
Mooseis2402
Thanks for the info and ideas. I checked out the 'Rolls Rite' trailers they look pretty good. Either I'll go that way or get a 6'10" and make the fenders removable.
hbixby
Dec 4, 2009 06:08 AM
bbri4570
Jan 24, 2008 01:21 PM
teepee542
All Things Towing
23
Nov 16, 2004 10:20 PM
ejohns06
Jul 14, 2004 12:51 PM
BroncoScott
Jun 27, 2002 12:54 PM
